Can anyone think of a potential solution for me to have both kits installed, without having to get my 12v battery replaced every year or so due to constant parasitic drain and recharging?
I’ve had it confirmed to me by EVOffer that the 12v penthouse under the rear seats (where my auto trunk is currently wired up to) is a switched live. They also explained why this causes me some odd behaviour - namely that when my car wakes up and I’m close enough the trunk will open, because the auto trunk ECU gets switched on. Apparently when the foot sensor receives power it activates, which opens my trunk. They said having the kit wired there could cause a variety of problems because of the surge current (?), although I’ve had the kit installed there for over 2 years now.
Wiring both kits to a constant 12v live - per the instructions - doesn’t work for my use case because of how little I drive the car. They will be slowly draining the 12v in the days/weeks I’m not using it. EVOffer say the parasitic drain is minimal, but It’s not zero.
Currently I’ve got a couple of ideas and I’m keen to hear thoughts:
- Wire some kind of inline switch on both kits, installed somewhere in the car that doesn’t require removing trim to access. If I know I’m not going to be driving the car for several days - I flick the switch and they are isolated from the 12v.
This solution has several downsides - I wouldn’t be able to use the frunk or the trunk from the app or keyfob, etc without having turned that switch on, so it’s extra hassle when putting things in the car.
- Wire up a lithium power bank that outputs 12v and install it somewhere in the car. Connect the output to the two kits, and the input to the switched 12v live (or one of the USB ports if it requires that for charging).
This solution would mean that the parasitic drain would be on the lithium battery, and so long as it had enough capacity it could run the kits for a reasonable amount of time, until I next drive the car.
The power bank would be recharged when the car is awake, but wouldn’t drain the 12v when the car is asleep. The kits would remain powered for access.
(I should say I’m not remotely electronically minded so wouldn’t really know where to start with this)
Thoughts?
