I'm going to drop by a glass/windshield company in the next few days and see what they say. I'll update you if I get news
Awesome. And yes, please post what they tell you. Hopefully something we can all do
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Thank you.
I bought molding which I put on the gap, front windshield A-pillars all the way back to the trunk area. And, across the windshield and roof, to fill the space, as I suspected they were creating noise. Don't know if it helps, but I think it does.
Hey Ken, can you please post exactly you did with the molding, including what you bought (a link would be nice), how you glued it, and any other prep/tips needed? And how about some pics to see what it looks like? Thank you.
As far as the 'Z' strip, does it protrude out of the surface? If it does, I wouldn't consider it myself, to be honest. The good news is I live with desert all around, and hardly see any rain, even when traveling. And don't remember using washer fluid at least in the last 2 decades. Ha ha. So not an issue for me.
I have also thought about filling in the gaps between the windshield, roof glass, and rear glass with the body panels with black silicone. But I decided not to because it might make future replacement of the glass very difficult and it might be hard to get a smooth bead of the silicone that doesn't get all over the place and varies in thickness (one of those silicone caulk aides would help).
I have the same concerns, but let me give you the reasons why I'm considering it. Yes, glass replacement would be more difficult for sure, BUT here's my take, so you guys can comment on that. First of all, silicone is flexible (unlike epoxy, which would be an absolute no-no), so it can be removed. And it'd solve basically all problems we're looking at solving: the gap, wind noise, and possible water intrusion in the future, as rubber gets old. Then, silicone can be removed. Or in our case, CUT. The only place where it would NOT be advisable to do that is next to the paint, for obvious reasons. Therefore, I'd only put silicone on the roof panels, since it'd be a very rare event if that happens. However, that cannot be said of the windshield, so I would not put silicone on the A pillars. But I would put it between windshield and glass panel. Just took a close look at it, and the windshield seems to have like a rubber 'lip', just like the glass panels as well. But it's the windshield that has that lip against the glass panel, so cutting the silicone right next to the glass panel would allow it to lift right up. And I'd do that myself, if my car ever needs glass replacement (which is unfortunately likely where I live). I'd look for another alternative to stuff between windshield and A pillar, since that gap not only looks bad, but I'm sure it's the source of quite a bit of wind noise as well.
Now, on the application. I'd start with taping both surfaces perfectly first, since it's almost impossible to avoid smearing silicone on top of the surfaces (probably both). And we all know how hard is to work and remove excess silicone. But after that, I honestly don't know which tool to use to smooth it out for a nice bead. I'm on the anal side, so I'm almost sure I'd be disappointed at the outcome (ha ha), but I don't want it to look horrible. So was selfishly hoping to learn from somebody else first. Ha ha. But apparently that won't be the case, so I'm open to all other easier implementations
. My main goal is to make those ugly gaps look better, and seal the area of concern as well.
Finally, I'd like to see a broken roof glass that was replaced, to see where exactly the hard adhesive was placed. I just looked at the glass panel again, and the translucid part of the panel is deeper than where the rubber gasket penetrated, but it still penetrated pretty deeply, as seen on the picture I posted. At least I feel better that water intrusion might not be present, but I'm not at ease yet, until I can see where water there would flow out of the cabin. Thank you guys for your comments. Hopefully more will come, and more details about possible fixes
. Have a great day.
