Ive been reading through the forums and as I understand there is no option to shuffle your songs/folders from your usb drive, I'm wondering is this still true on current cars / firmware of if this has been resolved on the new firmware?
Try shuffling Favourites.The Shuffle option was added over a year ago. it works fine now (just went and verified this; I'm on 7.1, version 2.17.37.)
And there the album art bug too. That said I only listen to thumb drive music for all it's flaws, it's better than the alternatives....not to burst your excitement bubble, but for your planning purposes, know that USB music still has a number of other unresolved firmware bugs,
Most of the time it doesn't show any artwork. Also it tends to show the latest loaded songs, and not older ones. That is, if I put some new songs on, the artwork will show, but some songs that previously had artwork will no longer have it.While I agree it's a huge annoyance seeing the wrong album art much of the time, esp if it's not a current or popular album, I personally don't believe it's a bug ... As much as it's just the way Gracenotes tries to offer up something most of the time if it can't find a better match -- e.g. it's why sometimes a picture of an artist (or someone or something else) shows up instead of an album cover.
I don't have the same problem as you. I rarely have a "blank note symbol" being displayed while USB music is playing, but I do perhaps half the time have something displayed that has nothing to do with the actual track, album or artist(s) involved. FWIW, the Gracenotes oddities appear about the same for me if I change the high-level folder name when I add or change songs on my USB stick or not. I suspect our music tastes may be quite different given your previous photo, so that may be part of why Gracenotes is better or worse for each of us. Again, I agree, it would just be best if Tesla would use album art if it's provided with the track so we could see what we intend -- it would even save Tesla data costs on the LTE connection not having to look-up and download Gracenotes images if they did.Most of the time it doesn't show any artwork. Also it tends to show the latest loaded songs, and not older ones. That is, if I put some new songs on, the artwork will show, but some songs that previously had artwork will no longer have it.
When I got the car firmware 4.1, maybe 90% of the songs showed artwork, now maybe 20%. And I doubt it's because Gracenotes doesn't have them as I put the thumb drive into a loaner and most of the artwork showed up (even though there were a few mistakes). There's some problem with how the artwork is fetched over time. The Service Centre wasn't helpful for this (and i really wouldn't expect them to be, as audio isn't their real function).
Without knowing further symptoms, your issue may be because of the way MS does not handle "album artist" correctly. If you run a Mac, "TeslaTunes" can offer help in this regard, or check out my article on my personal website to see if it offers any assistance. I tried to document a bunch of things I learned from TMC and my own trial-and-error there. I have many compilations and don't have as big of a problem any more these days.It still can't play compilation albums
Manually delete old MS Nav history
- Ensure I had not gone crazy with hundreds of Contacts being loaded to my MS from my smartphone -- set a reasonable threshold on your smartphone as to which ones are really required. (My former vehicles had a maximum of 2K contacts for each paired smartphone, but with Tesla allowing address information, who knows how that adds to CID memory consumption.)
- Ensure I only had a few Internet bookmarks stored on the CID -- not some crazy big number
- Ensure I'm not going crazy with way-too-many calendar entries and notes being sync'd to my MS, even though the maximum is just 2-days worth
- Temporarily remove my one (or two) USB devices
- Reboot my 17" CID
- Rebuild a single USB music stick with these constraints:
- As few levels of directory depth (parent/children folder construct) as you can. My previous vehicles had maximums of 6 or 8 in this regard. Depending how Tesla has written their firmware, this could unnecessarily cause significantly more CID memory use than you really need to keep your library organized for your purpose inside MS.
- Try running with less total tracks on your USB device. If you are running with thousands of tracks, I know I was having more problems at 16K, 14K, 12K, and 10K, than I do with just a few hundred like many owners likely run with (especially if they are internet music streaming fanatics, which I am not), or the ~6K tracks I have settled-in and run with now.
- Change the name of the upper-most root parent folder on the USB stick each and every time you change track content further down in the folder structure, if it's anything other than just adding tracks to the same stick. This is especially important if you do things like change genre on a track. The USB scan Tesla is doing does not pick up all changes you may make unless the folder names change -- I believe they do this to try and speed up subsequent rescans of what MS thinks is the same USB stick with same contents, but it's not a perfect implementation and can really make you shake your head wondering what's going on.
- Put that USB stick back into your MS and give it a go. Hopefully you have better results. I have, since I've done these preventive measures..
Not as Albums, but playing By Folder seems to work fine.It still can't play compilation albums
Play by folder works of you move all the songs on a compilation album manually into a single folderNot as Albums, but playing By Folder seems to work fine.
Yes, I've had the same issue, and it did require removal of the USB stick prior to reboot to get any audio including FM to play again. I do not use FLAC (generally M4A), and I play on USB random shuffle most of the time I'm in my MS.I occasionally see the same problem that rluciano mentioned, and it happened again tonight. I have roughly 1000 FLAC files on a 64GB USB stick (formatted as FAT32, IIRC.) These are the noticeable symptoms:
1. Song playback starts to stutter frequently.
2. The ability to toggle playback on or off by pressing the left scroll wheel no longer functions, for any playback source including the radio (it still works as a volume control, though.)
3. Shuffle and continuous play no longer work; playback just stops when the end of a song is reached.
Rebooting the CID did not fix things up immediately. I had to subsequently remove the USB stick and then reboot. After the second reboot, I tried turning the radio on and off with the left scroll wheel, and this time it worked. So I reinserted the thumb drive, it loaded, and continuous playback of songs is now working again as well.
A large memory leak (or an unbounded cache) could certainly explain these symptoms, but it's just speculation. I'm going to try putting a much smaller number of tracks onto the drive, say around 8GB worth, then play them more often on shuffle. If the problem reproduces again relatively soon, then it might be related to how much song data is processed rather than how many files are on the USB drive.
Yes. Issue when using the MS USB "Album" tab for playback (I assume that is what you and @thecloud are doing), is MS creates its list in that tab by appending the MP3-Album(Title) + (Track)Artist tags together. While MP3-Album is correct, Tesla uses the wrong Artist tag, which causes albums with varying artists on different tracks of the same physical album (e.g. compilations, Broadway, etc) to show as multiple albums when you playback using the built-in Album tab, rendering this tab useless for many music types beyond simple albums with a single artist -- assuming of course one has tagged their music the way the tags are intended to be used. If you put a specific album all in it's own folder on your USB stick, sure, playing back by folder will work since tags are not being used, but some of the other MS USB playback tabs will remain messed-up because of how Tesla scans and categorizes each track still using the tags.Play by folder works of you move all the songs on a compilation album manually into a single folder
