Thanks, this is all very illuminating.
Found some more good info in this old thread, too.
Nema 10-30? - Page 5
I never understood why Lowes/Home Depot/etc have bins of 10-30R's and 10-50R's since they are no longer allowed.That is a code issue. 10-30's are not approved for new installs, and then you get into the whole ground/neutral question on a permanent outlet in the house. Even though it is a little "Rube Goldberg", I would stay with the 6-30 to 10-30 cable/adapter and the 10-30 adapter for the UMC.
If you'll allow me to wax pedantic, there is no such beast - the NEMA L6 and L14 series max out at 30 amps. There are 50A twist locks (marine NEMA SS2-50 and the California Series/CS plugs), but they aren't part of the L6 or L14 specs.I did a little image enhancement and 180˚ rotate. See below. I read this as a L6-50R.
Ah. I'm moving to a house that already has a 10-30. I bought the adapter for the UMC. Should I pay to have it replaced with a 14-50?
Don't bother. That would involve running new wiring. Just use the 10-30, it'll be fine.
When I was researching high-current twist-locks for a project a while back, I did come across some reference that seemed to imply that 50 and 60A plugs may have existed in the L6 and L14 series, but either never made it into the standard, or were dropped early on. I found plenty of 50A 240 and 120/240 plugs, but nothing called an L6-50 or L14-50. In that case, I gave up and used an L6-30 (which was good enough):At least some think it exists. See NEMA Locking Plug and Receptacle Technical Drawings
Here is a clip from there...
NEMA Twist Lock Reference Chart
California Standard 50A Reference Chart
Inlaws just put a plug in their garage; they say it's on "at least" a 30 amp fuse, but don't know the plug type.
Here's a pic. The online guides I've looked at are ambiguous (at least to my untrained eye). Is this a NEMA 6-30?
The 14-30 Tesla adapter is supposed to be available. However, I don't see it in the store right now. Ask a service center. That is really the best way - using a Tesla adapter that is coded to the right current level.Since the 10-30 adapter is no longer available from Tesla, any suggestions on how to use this type of receptacle (L6-30)? It seems that going the route of [L6-30 --> 14-50] --> [14-50 --> UMC] and remembering to lower the Amps down to 24 is the way to go now?
Yes, it will work. All 14-XX outlets are wired the same way (a bit oversimplified; the 14-50 requires heavier gauge wire). The UMC does not use the neutral on a 14-XX outlet, just the ground.Maybe I'm misunderstanding the earlier posts in this thread but is the way the 14-30 is wired OK for this application? I'm curious why that route wasn't mentioned earlier and using a 14-50 was suggested instead. Since I cannot find any adapters that are [L6-30 --> 14-30] but I can find some which are [L6-30 --> 14-50] I'm presuming there must be something in the way the neutral is/isn't used.
I understand what you are saying about matching the amps (so I don't need to remember to manually change it) but I'm not sure that will work...???
The UMC and car don't care about the Neutral being open (N/C). You just have to label the adapter clearly that it's only for car charging because it can damage other equipment that does need the neutral. You will have to build the adapter custom because it's not a commonly needed configuration. You can find the L6-30 plug and 14-30 socket at Home Depot or other home improvement stores..Maybe I'm misunderstanding the earlier posts in this thread but is the way the 14-30 is wired OK for this application? I'm curious why that route wasn't mentioned earlier and using a 14-50 was suggested instead. Since I cannot find any adapters that are [L6-30 --> 14-30] but I can find some which are [L6-30 --> 14-50] I'm presuming there must be something in the way the neutral is/isn't used.
Looks like an L6-30 twist-lock connector. This has no neutral wire on it, so you can't convert to a 14-30, but you could convert this to a 10-30 receptacle and then use this adaptor on your UMC:
Tesla Gear Shop NEMA 10-30
In fact, since an L6-30 has no neutral (locking version of the 6-30; hot/hot/ground), the neutral on the 14-XX side of the adapter is unconnected.
The only real difference between an L6-30 -> 14-50 and an L6-30 -> 14-30 is the shape of the neutral slot on the 14-XX
Here's the reason for this. Very early on, Tesla had a lot of other types of official adapters: 6-50, 10-50, 10-30, 14-30, etc. Then they stopped offering most of them. For about 2 years or so, they only had 3 adapters available: 5-15, 5-20, and 14-50. Since 14-50 was the only high amp adapter you could get, and it came with the car anyway, it created this market at EVSEAdapters and some other sites for a "Swiss army knife" type of system of adapting everything to a 14-50 outlet, and then you could dial down the current to whatever level you needed. It was only very recently that they made the 14-30 adapter available again, and then it shortly went away again as part of the current recall.but I still wonder why I cannot find any adapters out there for [L6-30 --> 14-30] but can for [L6-30 --> 14-50]. As miimura says, it could be just because it is not common but not being an electrician, that makes me nervous and I'd rather try something which is officially out in the market rather than make one myself.
