vitesse
More lengthy?!@arg has given you some good advice, I had a somewhat more lengthy conversation with him when I was buying an extension lead. In case of interest here it is :
UK domestic 3 pin extension lead
Just wanting to play around with it, can you not make it so people can copy it?I probably will invite a few mods on to help keep it up to date now I've purchased my EVSE (Andersen A2) and it's primary purpose was to help my choice. However it's unlikely it'll be globally editable as it'll be a bit of a free for all. Is there an error/mistake or data you want adding on?
Baldrick
File/make copy worked for me?Just wanting to play around with it, can you not make it so people can copy it?
would it be sufficient to install a 7kwh home charger?
As an interim solution for slow charging at home or when visiting family my assumption is that I can simply plug the Tesla mobile charger (that comes with the car) into a standard wall socket and charge the car from that. Am I correct? No issues with overload in doing this?
More lengthy?!
Anything over 32A (P=V*A) =~7kW requires 3 Phase AFAIK.Does 11kw charging need 3 phase? Most on Baldrick's sheet are only 7kw...
7kW is similar to cooker wiring ... maybe you will charge your car overnight to get best off peak tariff ... in which case Cooker, Power-Shower, Car won't all be on at the same time ... but ... the higher your house limit / fuse / "tails" are the more you can do simultaneously and not have to worry about it.
Car has ability to do geofenced schedule charging - e.g. you can set charging to start at say 1AM when at "home" and it will charge straightaway when at "work", so you would have to explicitly override scheduled-charging at home if you needed to go out again "soon". Thus unlikely you will have car charging same time as "cooker"
Worst case you can get a device that will stop the car charging whenever other household loads exceed threshold.
The UMC cable that comes with the car will plug into a 13 AMP socket - about 6 MPH, so should get you 70-ish miles overnight.
Only real issue is that the wiring for the socket you plug into might not be great for continuous operation at 13 AMPs (realistically 10 AMPs). Whenever plugging into an unknown socket I always check if the plug gets warm after 30 minutes or so, and before going to bed. You can reduce the car charge rate (from dashboard) if that is the case - will take longer to charge of course - or try a different socket - e.g. nearer the consumer unit, rather than the tatty one hanging off the wall in the shed, with the frayed lawn mower extension attached!
If you need an extension lead (e.g. when visiting Rellies) I recommend getting a "proper one" of sufficient cable diameter (to prevent voltage-drop and overheating), and with tough outer protection. See @arg's comment upthread Home charging options
No worse than running a tumble dryer or similar.
I should be fine with getting the fuse upgraded to 80 amps
in a restaurant kitchen where the induction hob may let them get more cooking done on the same number of rings
A heads up for any folks in the North West if you need a fuse upgrade - they seem to be doing upgrades in some other areas of the country for free but Electricity North West charge for it, it’s £120
Actually, with the small amount of load that you listed (no electric showers or other heating), you'd almost certainly never blow even the 60A fuse with a single chargepoint and the rest of your existing loads. People are often spooked by induction hobs with their "30A" rating, but in fact they don't use any more energy than a conventional hob - actually slightly less as they are more efficient - they just use it over a shorter period. So if you are doing the same amount of cooking then you don't use any more energy and for a domestic kitchen it's reasonable to use the same numbers in a demand calculation as for a standard hob (the argument could be different in a restaurant kitchen where the induction hob may let them get more cooking done on the same number of rings).
Upgrade to the 80A fuse should be plenty.
Anyone know what charge adaptors (if any) come with the M3?
I'm hoping to use the 7kw PodPoint we have at home but its a tethered Type 1 so will need an adaptor to convert to Type 2.
Still using Type 1 for Outlander PHEVUnless you are still using the Type 1 it might be better to get your PodPoint converted directly to a Type 2 rather than use an adaptor.
Useful Info from the Tesla website:Anyone know what charge adaptors (if any) come with the M3?
EDIT: Does anyone know if the onboard chargers on SR+ and LR/P models are different? I've see both 7Kw and 11Kw mentioned but I'm not sure which is accurate, maybe 7 for SR+ and 11 for LR/P, or both 11 ?
Had my EO charger installed yesterday. Turns out I have a 30A fuse on a cable head that looks like it's been around since the turn of the century (previous one) when the house was built
No showers or cooking while charging until I get that replaced!
