Yeah, it doesn’t matter, and that’s the usual problem, we need a common place for common problems....By the way, I didn't realize that this is the X forum. ^^ My post above is for a 2014 Model S.
We had a similar occurrence leaving, with auto-close on. It seems to be repeated sending. I finally turned off auto, and then closed it manually.New problem - last night I wrote about how it, after a reprogram, already failed once. Today when i got home, the door opened about a foot and stopped, as if the car sent a double signal.
I reported on another tread that my gate and garage both failed (rebooted 3 times) after upgrading to 2017.40. I then noticed that .40 actually turned Energy Saver ON where I had set it to OFF before. Since turning back to OFF it has not failed. Maybe too soon to tell.
Worth a try. It still has not failed in my case. And as I said it failed three times right after 2017.40 was installed and Energy Saver was turned on by that update. Good luck. If it turns out to be the cause maybe something Tesla can fix.I'll give this a try. Not sure why this would matter, but worth a try anyway.
2017.40.1 Homelink failed on our Model X today.
Strange. I wonder what else could have fixed my problem (if actually fixed)? I guess I will review if it starts failing again.Nope, Energy Saver was off on the car when I went out to change it, so guess that is not the cause (or related).
I usually open the garage with the button when I enter the garage so not the same. My failure was happening when I tried to close it once I back out of the garage. However, after setting Energy Saver Off (with Always Connected On) I tested inside the garage many times with opening/closing both my 1 and 2 car garage doors and it did not fail. Because another posted said Energy Saver does not affect him I have no idea what it is.So, I've tried to figure out the recent failed behavior of my HomeLink and am putting this out so others can also see if there is any commonality. My problem is that the first time of the day when I try to use HomeLink to exit the garage, it invariably fails to transmit, i.e. no signal indication when you press the 'button'. But what I've found is that once I exit my garage manually and go run around, when I come back, it invariably works again (signal indication), and stays working the rest of the day, without me actually doing anything to fix it. I've experience this now on two consequtive days. Would be interested to see if others experience match mine or if this is just a random occurrence.....
So, your first use of the day is to try and close your door, and it doesn't work. That is essentially the same for me. My point was that after driving around for a while and then trying it again, it seems to work again and stays working for the rest of the day. But the next morning, it happens again. Perhaps there is something that happens during sleep that prevents the HomeLink from working right away upon wakeup.....I usually open the garage with the button when I enter the garage so not the same. My failure was happening when I tried to close it once I back out of the garage. However, after setting Energy Saver Off (with Always Connected On) I tested inside the garage many times with opening/closing both my 1 and 2 car garage doors and it did not fail. Because another posted said Energy Saver does not affect him I have no idea what it is.
Well to be clear. That was the problem I was having. I no longer have that problem per my post. It has not failed since I made the change to my settings per my post.So, your first use of the day is to try and close your door, and it doesn't work. That is essentially the same for me. My point was that after driving around for a while and then trying it again, it seems to work again and stays working for the rest of the day. But the next morning, it happens again. Perhaps there is something that happens during sleep that prevents the HomeLink from working right away upon wakeup.....
What version of firmware/software are you now on? (mines broken on 17.38...)I took my to the SC and they knew about the problem, I got a software update and its fixed.
