Xtek
My new (took delivery 4 weeks ago) X didn't work when I first brought it home, very unreliable. I decided to re pair and now it hasn't failed once.
I'm on 17.34.
I'm on 17.34.
Looked at this a little closer on the loaner, my bad, it's open on arrival, and close on leaving only. Guess they don't want to do any movement when the car is inside or near the door, makes sense!On the ‘not useful if the door is already open’, you can set it to beep when it’s going to automatically open the door. You then have the popup that gives you the option to cancel it.
I find it works perfectly for arriving home except for the current works once or twice scenario. As said, Tesla is producing a fix. When it gets to us, who knows.
Question: Is the ‘auto open on leaving’ from inside a closed garage supposed to work? How does it know you are leaving? Car in reverse?
That's as designed, if you have that option checked. D...and my HomeLInk has magically started working. I had not reset the MCU or anything. Strangely enough now I hear a chime when I approach the garage. This is a first and new!!!
Mine on 17.36 and 17.38 did that, the only part that didn't work was the doing it over and over part....
You sure the car didn't reboot for a firmware install or something to reset things? It usually doesn't fix itself, but we've seen weirder!
Hm, that's a new bug, obviously. All I ever noticed was the failure to transmit (the wi-fi-ish icon and the actual signal). The car actually popped up the notification and chime and option to skip opening if wanted, but then just couldn't do it.My chime never worked but the garage opened on my previous firmwares without a hitch when I approached the driveway. On the new firmware it suddenly stopped working for days and now it works without a reboot.....including the chime
Hm... #2 is hopefully (for us) localized to you.I feel like there are two problems with homelink that I am experiencing -
1) Pressing the virtual button does not appear to activate the radio. Specifically, it doesn't show the little "wifi" signal on the right side of the button. Or it is severely delayed. I've experienced this 2 times and had to reboot the center console.
2) The virtual button does show the "wifi" signal and the door doesn't open. Reboot does not fix. I typically have to move closer, back up, etc.
I believe I have resolved #2 by adding a new receiver to my old opener. But hard to tell for sure. Reprogramming it appeared to fix problem #2 in the past as well.
See this thread: Homelink — Change Transmit Mode
Does everyone on 17.38 or above have this new ‘Change transmit mode’ option?
Or is it limited to some new hardware that perhaps came with AP2.5? I think there are too many issues for it to be hardware related.
Homelink seems to be working for me on version 17.40.1 after the update today. Will see how it performs over time, previously the homelink used to stop working after a while.Seems to be very variable. We hope the fix is in 17.40.1.
You could sit there all night and open and close your garage door...Homelink seems to be working for me on version 17.40.1 after the update today. Will see how it performs over time, previously the homelink used to stop working after a while.
Sadly they don't pay me to testYou could sit there all night and open and close your garage door...Nah, probably a bad idea.
