More testing answers questions and clarifies, but also opens up new questions:
Is "typical range" varying with each car, depending on it's driving history, or is it a constant value embedded in the software/firmware?
After charging today, I confirmed that the 3-phase chargers, as delivered to the Hong Kong market are NEITHER limited to 40A/80A for single/dual chargers, NOR are they limited to 10kW/20kW.
Here was todays testing:
Charging equipment: CLP 3-phase/32A type 2 (22 kW)
Voltage: Varying between 217-219 V AC as measured by my car
Ampere: 32A/3 - as advertised
While I had 21kW indicated inside the car, it was flickering to 20 kW at times (there are no decimal places indicated, just whole kW). On the charging station it said it delivered about 1.2 kW more than the car indicated it got (cannot be seen precisely as the car rounds off to whole kW, however, V AC and Amp can be used to find it around 20.8 kW at most times, fluctuating to over 21 kW when voltage is 219 V AC).
When stabilised, charging showed
94 km/h for typical range, and 117 km/h for rated range, 20 or 21 kW, depending on actual voltage (217, 218 or 219 seen). The CLP charger showed around 22.2 kW given, and after 52 minutes of charging, it said I had used 19.126 kWh, which amounts to an average gross charging power of 22.07 kW. I had the center screen on most of the time, while the air con was off. Overhead was hence just over 1 kW, accounting for losses in the cable, running the chargers, screens and various other systems. Including all these factors, charging efficiency seems to be 94% from charging station output to battery (excluding what the charging station itself uses and before, and eventually using the power from the battery)
My calculations show around
177.5 Wh/km for rated range, and 222 Wh/km for typical range. Since my car so far has average 221 Wh/km, I was thinking if the typical range is being set to the cars life long average, or a fixed value. Or is it a coincidence that my calculation of 222 Wh/km is within 1 Wh/km of my own average use so far?
This means that the charging chart has been updated, see below. Most of the values depicted are still calculated, pending practical confirmation by testing (
need car with single charger to try some locations and report back please)
Please note that overhead in the car, as well as energy used to cool (or heat) the battery isn't proportional to the charging rate. Hence, very low or very high charging rates will be less efficient than some mid range charging level. 13A BS1363 charger, is cut down to about 10A by the Mennekes adapter that Tesla sells for 3,700 HKD, while charging is about 9 km/h when all goes well. The "km/h" indicated in the table are NOT corrected for different efficiencies, at different charging levels. Also, it depends on whether air con is running or not. For BS1363 and 10A net charging, running the air con lowers the charging rate from around 9 to around 2 km/h.
