No I believe it's a dual 2.4/5 GHz antenna that is poor quality and has a long cable run to the wifi module which attenuates the signal. The 5 GHz signal has already been attenuated more than 2.4 GHz passing through objects so what the wifi module receives is very weak.
To be as bad as the signal is... The antenna and cable run would have to be so poor quality it's beyond belief.
I can use a 10m sma extension cable on a cheap WiFi router and a paper clip for an antenna and get a better signal - yes I've tried.
I just can't assume there is any real attempt to support 5ghz on the car, even incompetence would give a stronger signal.
