And you never had an OEM battery last longer than 14 months?
I used Google and pulled weather averages Verbier came up as "rarely below 7F or above 73f" Chicago came up as "rarely below 5F or above 91F". There is a lot of USA north of Chicago the city I like near comes up as rarely below -7F and rarely above 89F, and there is a lot of the USA that is colder than where i am too and certainly a lot that is hotter.
I looked at the Ohmmu two years ago for my S and they wouldn't give me a temperature they knew it had been successfully used at, yours is the coldest I have seen someone say they are using it and I am gladd it has worked sofar but who is to say it makes it thru another winter.
I know the OEM replaced in my car which is only the second battery the car has had has been fine at -20F.
I don't know the difference between the S and 3 12volt, anyone know if it is the same chemistry?
@camalaio while I agree ICE batteries placed under hood see much higher temps, they are also not subject to the charge cycling a Tesla battery is, I suspect the apparent temperature issue is affected by that.
