(closer to "real world" 200 miles)
Remember that Elon has stated something like that you need 240 miles EPA to get "real world" 200 miles. 70D gets 240 EPA miles, and I will guess Model 3 will also get (around) 240 EPA miles.
THISRemember that Elon has stated something like that you need 240 miles EPA to get "real world" 200 miles. 70D gets 240 EPA miles, and I will guess Model 3 will also get (around) 240 EPA miles.
I imagine that the reduction in size and gigafactory production will help keep battery costs low. Wouldn't need as large of a battery to power a Model 3 (especially if they drop its power)
Perhaps another reason they pulled the 60kwh Model S was to hold onto the batteries to use in Model 3?
If you think about it this way, they could potentially work with:
Model 3 - 50kwh
Model 3 - 60kwh
Model S - 70kwh
Model S - 85kwh
Model X - 85kwh
Model X - 95kwh
(I'm really hoping there's a Model 3 60d or p60d option!)
That seems a bit of ICE-tinted thinking. While of course I can't know for certain, the cost delta for improved performance in an electric drivetrain is going to be nothing like the cost delta of going from a naturally-aspirated 4 cylinder ICE to a turbo four, or to a V6. Doubling the EV power output requires maybe 50% more copper in the motor, bigger HVDC connectors and twice as many, or higher-capacity IGBT's in the motor controller. It's nothing like the extra bits required to double ICE performance.
I'd love them to take a page out of BMW's i playbook and go with a carbon fiber body structure with highly-automated manufacturing. Yes, CF is expensive, but you get a huge reduction in parts count (many fewer presses and stamping die sets required), assembly is simpler (robotic gluing), material handling is cheaper (body parts can be moved by workers without hoists, or smaller robots), and the resulting vehicle is much lighter, so you can put fewer kWh into the battery pack for the same range, handling, acceleration and stopping gets better... It's just better (provided you don't let BMW do the styling....)
Seems unlikely for the Model 3 though. Maybe for the 4th model...
How current is that research paper? I would expect the cost differential to be less than it once was, given the F150 now has an aluminum body. It doesn't get much more mass market than that.So my 15 minute googleing into the topic tells me, that according to an MIT research paper, producing a body in white out of steel is about 50% less expensive than aluminium. They ran some numbers on cars with full alu bodies, vs some parts (doors, hood, trunk) made of alu vs all steel.
While that would surely have some weight consequences, there is a cost factor to consider there.
Unless more than 2/3 of S and X are 95 kWh, Tesla can prodyuce EVERY model 3 with at least a 60 kWh pack with 1 gWh to spare. They put in the Gigafactory pdf that they will have 35 gWh going into 500k vehicles in 2020. The math is really easy. Even if every S and X had a 95 kWh pack, they can put 59.25 kWh packs in every model 3. They said no packs larger than 85 kWh for the s and X for a few years. That would mean that every model 3 could have a 63.5 kWh battery if every single model s and X is an 85.
Long story short. Model 3 has an average battery capacity of 60 kWh and if they go smaller, they'll have packs they don't have cars for.
Lower discharge rate batteries are not cheaper but have less capacity.I am not a battery expert, but wouldn't itbe true that they could use cheaper cells that do not need to cope with the high discharge rate demanded by the Model S warp engines?
Easy...
Steel wheels with hubcaps instead of alloys.
No heated seats.
Smaller body less material.
Use steel.
Plastic everything from handles to wing mirrors.
Everything manual operated from trunk to windows.
Cheap as chips. :smile:
I have seen $180/KWh mentioned ...
One minor talking point. I think supercharger access will be included in the base price. All the variations of the model s have it included. If it wasn't included you might get a naïve person trying to travel with the base model 3 with no access to superchargers.
Come on, this isn't going to be a car somebody picks up at the corner store on the way home. They may decide to include supercharger access in the base car, but if they don't customers will be well informed.
