Not too likely that we will.
I was questioning why a long range car (say 100kWh+) just HAS to be mated with motors which are combined able to match the battery's maximum discharge rate.
Pretty sure the question has been asked and answered by Tesla Motors Engineers time and again. In order to build a compelling car that is not slow and that makes the proper impression... YES. Toyota can build a fully electric Camry. No need for Tesla to do it for them.
Can't a motor setup be found that wastes less heat to cruise are 100-120kph?
Sure it can, by gimping it.
OK, cool, so the 100kWh pack CAN deliver 500kW or more to the motors now. But should the motors spec'd by default be able to match the battery discharge rate?
Yes. In fact, the motors should be specified to handle 750 kW
(1006 HP), or 1,000 kW
(1,341 HP) if possible. That is feasible, affordable, reliable, and durable, etc. The batteries with appropriate capacity and voltage/amperage can come later to take full advantage of that potential output.
A 2-ton car surely has plenty with 200kW. Perhaps it would suffer more (waste heat) when being pressed to extract this 200kW or even 100kW for an extended period of time than the now popularized 500kW approach. I wouldn't know, and ask to learn.
We aren't talking about ICE vehicles here. The Toyota Camry XLE V6 weighs just under 3,500 lbs and has a 268 HP engine with 248 ft-lbs torque. According to
Car and Driver that car is:
Proof that good enough sells.
"Pumping out a healthy 268 horsepower, the V-6 car can scoot to 60 mph in 5.8 seconds and through the quarter-mile in 14.3 seconds at 100 mph."
And, to your point, 268 HP just happens to correspond to 200 kW. By my best guess is that would not qualify as particularly
'compelling', or even competitive in comparison to cars such as AUDI A4 2.04T Quattro, BMW 340i, Cadillac ATS 2.0T AWD, Infiniti Q50 RED Sport, Jaguar XE, Lexus IS, and Mercedes-Benz C300. I expect the base Model ☰ to be on the quicker side of
'under six seconds' 0-to-60 MPH and over 300 HP, so better than 402 kW in rear wheel drive form. The kick in the pants one might get from instantaneous torque is cool... But having that last through semi-legal speeds is even better.
I suppose it may come down to why motor layout and scale produces the least heat in the range of cruising power, say 15-35kW?
Wait... Hunh?
What?!?
