mikes_fsd
Banned
Is there any power in reserve once the indicator reads zero?
I drove my X on 0 for about 5 miles to reach a super charger.
Like others have said, stay at <=35, light acceleration and max regen, should be good.
And yet another person adding to the myth. STOP!I drove my X on 0 for about 5 miles to reach a super charger.
STOP POSTING CRAP LIKE THIS!!!
It is crap. And if you are driving 12 miles past rated range after hitting zero, then there is something wrong with your car because the calcs are way off. By posting crap like this you encourage others to do the same based on a false assumption and I will continue to shout it every time someone says it so others do not assume it is correct - THERE IS NO DRIVING RESERVE PAST ZERO RATED RANGE.Easy here. It is not crap. I have had my car for 2.5 years and have driven passed zero several times and my car never shut down. I do not recommend it, there is no guarantee whatsoever, but mine and many other people's experience is that the car will likely not *sugar* down right at zero. Many thing factor in. Gentle driving and road conditions make a big difference. Just recently I drove 12 miles passed zero (favorable road conditions, though).
you know that filled up tires, stay filled up for weeks or months? so filling them up is never a energy waste. why is stopping a an energy waste at all? motor is not running while standing still
the only time when low pressure helps (for safety), is in my humble opinion, in sloppy weather conditions like snow or wet leaves.
Uhm, I never said there was a reserve... no need to yell or get your panties in a wad!And yet another person adding to the myth. STOP!
Just because your car's calculation of range was off DOES NOT MEAN EVERYONE'S IS. THERE IS NO BUILT IN DRIVING RESERVE. Zero should be treated as zero. If you are at 5 rated miles remaining and can drive 25mph without interruption then you can stretch it to 10 miles (or even more - I have), but once you hit zero you CANNOT ASSUME THAT THE CALCULATION IS INCORRECT.
Read the posts above.
It's not a story that he needs to change, there is no magical reserve. You might get lucky and drive a little beyond zero, you might not. A person should not PLAN to drive below zero.@thefortunes now will you change your story?
And with well over 100k EV miles I will continue to shout for all to hear - THERE IS NO RESERVE PAST ZERO RATED MILES ON THE MODEL S. IF YOU ARE LUCKY TO DRIVE PAST ZERO, YOU ARE JUST THAT, LUCKY (OR YOUR CARS CALCULATED RATED RANGE IS OFF).English is not my native tongue, but where do you see me referring to a reserve?
Range number is derived from a formula, if you change the input parameters (i.e. your driving style) you can change the range number.
PSA: there is no reserve, but if you drive like a grandma you can get a few more miles out of rated range... as an example (demonstrated with graphs and all): I got about 5 more miles using said method!
smh
Oh, one more thing...
This is not unique to Tesla... with over 40k ev miles now behind me, every ev I've driven reacts the same way. Slow down, drive gently (grandma like) and you get a few more miles out of the battery.
My car is in a parking lot with 25 miles of range and no charger. Nearest supercharger is 38 miles away. Is it possible to drive in such a way as to squeeze 38 miles out of a battery with 25 indicated?
Changing your style of driving (i.e. hypermiling) will certainly get you more range, but not once you run out of electrons (which is what zero means). DO NOT PLAN TO DRIVE PAST ZERO RATED RANGE.
No one does that.
Guys, I'm new and researching.
Is there not an App or something that shows all charging locations, SpCs, and even user found outlets? Some way to locate the nearest source of electricity and plug-ins?
I think it would be cool to have a user based GPS list of known charge locations that you could use in a pinch.
