I'm sure you will have your answer in a Flash(erZ).Will a HPWC crimped with a plug to a NEMA 14-50 socket be safe? I am worried about heat, stability, breaker tripping, fire under 40 Amps
-OL
This way the NEMA 14-50 can be used as a backup in case the HPWC fails; anyone know the warranty on the HPWC?
-OL
Being out of spec with the NEC does not make something illegal.
40-10-10 PENALTIES.
(A) Any person who is convicted of a violation of this Code shall be fined not less
than One Hundred Dollars ($100.00) nor more than Seven Hundred Fifty Dollars
($750.00), plus costs, including court costs and attorney fees. Each day that a violation continues
shall be considered a separate offense.
(B) Nothing contained in this Section shall prevent the City from taking any other
lawful action that may be necessary to secure compliance with this Code
A. It shall be unlawful for any person, firm, or corporation to knowingly erect, construct, enlarge, alter, repair, move, improve, remove, convert or demolish, equip, use, change the occupancy, occupy or maintain any building or structure in the City of Olympia, or cause or permit the same to be done, in violation of any of the provisions of this Code. Such a violation shall be a misdemeanor punishable by a fine not to exceed One Thousand Dollars ($1,000) and/or imprisonment not to exceed ninety (90) days or both such fine and imprisonment. Each day shall constitute a separate offense. In the event of continuing violation or failure to comply, the second and subsequent days shall constitute a gross misdemeanor, punishable by a fine not to exceed Five Thousand Dollars ($5,000) and/or imprisonment for not more than three hundred and sixty-five (365) days or both such fine and imprisonment.
B. As an additional and concurrent remedy, it shall be a civil infraction for any person, firm, or corporation to erect, construct, enlarge, alter, repair, move, improve, remove, convert or demolish, equip, use, occupy or maintain any building or structure in the City of Olympia, or cause or permit the same to be done in violation of any provision of this code. Each day shall constitute a separate civil infraction. Any person, firm, or corporation found to have committed a civil infraction shall be assessed a monetary penalty as follows:
1. First offense: Class 3 ($50), not including statutory assessments.
2. Second offense arising out of the same facts as the first offense: Class 2 ($125), not including statutory assessments.
3. Third offense arising out of the same facts as the first offense: Class 1 ($250), not including statutory assessments.
In most jurisdictions, it is, indeed, illegal.
In fact, in some jurisdictions, it's more than a citable offense - it's a misdemeanor...
I've pointed out some cities in the US where it's considered a misdemeanor, punishable with jail time and fines.
I thought it looked really familiar. I'll ask you then. Is there any reason you didn't rotate the 14-50 socket 180 degrees and just attach a short (12" or so) cable to the HPWC and mount it directly above the 14-50 socket?
Anyone know if Home Depot or where to buy a 12" - 14" short AWE 6 cable with NEMA 14-50 plug on one end to use on the HPWC?
Know of one online? Im not too familiar with one around where I live.Ca
Can you not just have an electrical shop build you one?
