A couple of more observation on IR photos: I put my HPWC on charge at 40 amps, waited about an hour and put the IR camera on it. First and most interesting: the Cylon eye does not show up except very faintly. The LEDs don't emit in the part of the spectrum to which the camera is sensitive and the amount of heat generated by them is not enough to warm the surrounding area appreciably.
The rest of the unit (covers on) was at pretty uniform temperature representing a rise of about 10 °F above ambient. The wires showed a rise of about 20 °F above ambient except where doubled and tripled in being wrapped around the unit where they showed 40 ° rise. The wires inside the box would be at least as hot or hotter but they did not image through the covers.
Good post.
It’s not the light your IR should pickup on LEDs, but the heat they still put out. Also the circuits driving them also output heat. Try it WITHOUT it cycling. I bet they are a little above average heat there. Every LED I point my IR at lights up far brighter than the eye sees. It’s all relative. If the case was warm from charging the little heat the LED does give off might not stand out.
For shits and giggles here is a V2 Supercharger after 35 minute charge. Should I report this to Elon my car is gonna catch fire if he doesn't lower the current? BTW, the handle was luke warm.
