jimmy_d
Deep Learning Dork
So my backup method of getting a definitive answer about usage of the additional NNs failed as well, so I broke down and went for the indirect way (for now anyway).
If you jack up debug to the vision task - it only tells you that it loads and initializes the main_narrow NN, not the other two.
The file locations was a bit reshuffled compared to prior releases so I it's possible somebody forgot to filter the new names from th efinal release, or it might also mean that the code to use the new NNs is really around the corner.
Is it possible that the other cameras don't run all the time?
EDIT:
Here's a weird idea: what if the repeaters, just one of them, turn on when you activate a turn signal? So basically it looks in your blind spot when you signal. Conceivably that would only happen during autosteer, I guess.
