I knew it. I knew it, I knew it, I knew it. Tesla: I knew it. Whohoo. Verygreen made my day. CASE CLOSED!
Ummm, @verygreen made our day long long ago, he just continues to make it....
BTW the NNs have names. The wide zoom one is called.... tada! fisheye_autowiper
All this technical but I have a very simple question: is the lower resolution mentioned during processing the reason why the car won’t detect stopped cars on red light when you come in too fast because the car is too small for the pixel resolution?
Is it also why it get confused with old highway lines vs new ones?
How could we know they processed high res images to accurately do the FSD demo and actually see a stop sign from a safe distance away ?
Perhaps some of the NN’s can run at a lower frame rate and higher resolution, or intermittently? Like the lane change cameras likely don’t need the same update rate as maintaining lane position or looking for forward obstacles.
A friend gave me a copy. I also recently received copies of earlier versions, so I'm going to take them apart to see how the network has been changing over time.
The bottom 21 layers of the network stack is 100% GoogLeNet, with only a single difference. Because GLN outputs a label it doesn't need to preserve position information, so they drive the frames all the way down to 1/32 of full size (with 1024 layers in 5b) in GLN before using using linear+softmax to generate the label. But 40.1 only goes down to 1/16 size even though they keep the 5a and 5b with the original GLN kernel depth. Because Tesla is re-expanding the frames and generating output frames that retain position data they probably need to avoid getting too small. This makes layers 5a and 5b 4x as compute intensive in 40.1 as it is in GLN (2Gops per frame).
Have been thinking about why they would go to frames as output instead of coordinates or labels or something easier to process at the back end and it struck me that they could be training the bottom 21 layers unsupervised by building inception as an autoencoder. Am going to see if I can find any examples of other people doing this - maybe the output deconvolution layers are 'borrowed' from another project too.
It used to complain that it cannot open sqlite db that indeed was not there. This firmware comes with a db schema so I imagined it would create the db. Alas, it does not (not on my car anyway). But the message in the logs changed to something about contacting maps task now.
I thought the wide angle lens was needed for sign recognition and cross traffic situations with pedestrians and such, I suppose they can just add another NN called GodFather to look for signs and pedestrians and such, however I assume each NN requires a certain amount of resources to spin up / and run it's process, so does combining NN make them more efficient to run later on, or is it typical to have large amounts of small networks for specific tasks and just have one master NN to rule them all and make decisions?
Just for fun I downsampled some frames grabbed from some of the HW2 cameras under different conditions (source) to 104x160. Kind of gives you a sense of what level of detail we're talking about. These are full size (Try zooming in 500x.)...
I mean is this what the AP2.5 ECU is actually dealing with? Why on earth do they have such high-res cameras and camera sensors installed? Despite @jimmy_d's excellent posts, my brain doesn't seem to comprehend this. Instead, my brain screams the question: Wouldn't the reasonable thing to do be to exploit every single pixel from the new camera sensors? Shouldn't we expect to have an on-board computer that chews through all of it, even if it would spit much of it away after doing it's thing? Why downsample before Vision gets a chance to look over it?
And how about this Tesla job ad description:
Just asking. Hoping for intelligent answers...
Just a thought -- this is very possibly why street signs are still not being read and interpreted. There are nowhere near enough pixels to pull meaningfully accurate data off the street sign at that resolution...
He stated this: "so I imagined it would create the db" right before "Alas, it does not (not on my car anyway)." so he must meant it didn't create the db/database."Alas, it does not (not on my car anyway)." It doesn't do what on your car?
roads, road_splines, lanes, lane_splines, traffic signals....Can you share some of that information in the DB schema? like table names and such?
"snapshot-version": "0.3",
"wall-time": "1508987636850212162",
"monotonic-time": "1185683024834",
"sha1": "a88c8d597f1c5eb1",
"requester": "autopilot-trip-log",
"faux-board-id": "2e563f1d-7b53-4a66-afc8-2c32b4d9a672",
"request-clock-type": "monotonic",
"request-trigger-time": "1185682931785",
"boot-sec-info": "0x00000002",
"vehicle-type": "M3-RHD",
"hardware-type": "HW2.5",
"product-release": "2017.42 (develop-2017.42-6749-a88c8d597f)",
"cameras": {
"main": {
"pixel_format": "RAW12_NVIDIA",
"color_filter": "RCCC",
"width": "1280",
"height": "960"
"narrow": {
"width": "1280",
"height": "960"
"fisheye": {
"width": "1280",
"height": "960"
"leftpillar": {
"width": "1280",
"height": "960"
"rightpillar": {
"width": "1280",
"height": "960"
"leftrepeater": {
"width": "1280",
"height": "960"
"rightrepeater": {
"width": "1280",
"height": "960"
"backup": {
"pixel_format": "UYVY",
"color_filter": "RGGB",
"width": "1160",
"height": "720"
"entries": {
"autosteer": {
"time_s": {
"autosteer_on": {
"ROAD_CLASS_UNKNOWN": "0",
"ROAD_CLASS_1": "77",
"ROAD_CLASS_2": "0",
"ROAD_CLASS_3": "0",
"ROAD_CLASS_4": "24",
"ROAD_CLASS_5": "0",
"ROAD_CLASS_6": "0",
"SPEED_UNKNOWN": "0",
"SPEED_NEGATIVE_MPS": "0",
"SPEED_0_TO_5_MPS": "0",
"SPEED_5_TO_10_MPS": "0",
"SPEED_10_TO_15_MPS": "0",
"SPEED_15_TO_20_MPS": "9",
"SPEED_20_TO_25_MPS": "11",
"SPEED_25_TO_30_MPS": "80",
"SPEED_30_TO_35_MPS": "0",
"SPEED_35_TO_40_MPS": "0",
"SPEED_40_TO_45_MPS": "0",
"SPEED_45_TO_50_MPS": "0",
"SPEED_50_OR_ABOVE_MPS": "0",
"CURVE_RADIUS_UNKNOWN": "0",
"CURVE_RADIUS_0_TO_100_M": "0",
"CURVE_RADIUS_100_TO_250_M": "0",
"CURVE_RADIUS_250_TO_500_M": "5",
"CURVE_RADIUS_500_TO_1000_M": "4",
"CURVE_RADIUS_1000_TO_2000_M": "17",
"CURVE_RADIUS_2000_TO_5000_M": "36",
"CURVE_RADIUS_5000_TO_10000_M": "22",
"CURVE_RADIUS_10000_TO_100000_M": "11",
"CURVE_RADIUS_100000_OR_ABOVE_M": "3",
"GPS_FUSION_OFF_S": "0",
"GPS_FUSION_ON_S": "101",
"GPS_FIX_OFF_S": "0",
"GPS_FIX_ON_S": "101",
"SATELLITE_RANGE_0_TO_3_S": "0",
"SATELLITE_RANGE_4_TO_7_S": "0",
"SATELLITE_RANGE_8_TO_12_S": "0",
"SATELLITE_RANGE_13_AND_UP_S": "101",
"CELL_NOT_CONNECTED_S": "0",
"CELL_CONNECTED_S": "101"
"autosteer_available": {
"ROAD_CLASS_1": "2",
"ROAD_CLASS_4": "97",
"SPEED_0_TO_5_MPS": "2",
"SPEED_5_TO_10_MPS": "9",
"SPEED_10_TO_15_MPS": "28",
"SPEED_15_TO_20_MPS": "37",
"SPEED_20_TO_25_MPS": "12",
"SPEED_25_TO_30_MPS": "9",
"CURVE_RADIUS_100_TO_250_M": "6",
"CURVE_RADIUS_250_TO_500_M": "9",
"CURVE_RADIUS_500_TO_1000_M": "18",
"CURVE_RADIUS_1000_TO_2000_M": "21",
"CURVE_RADIUS_2000_TO_5000_M": "20",
"CURVE_RADIUS_5000_TO_10000_M": "7",
"GPS_FUSION_ON_S": "100",
"GPS_FIX_ON_S": "100",
"SATELLITE_RANGE_13_AND_UP_S": "100",
"CELL_CONNECTED_S": "100"
"autosteer_unavailable": {
"ROAD_CLASS_UNKNOWN": "8",
"ROAD_CLASS_1": "5",
"ROAD_CLASS_4": "174",
"ROAD_CLASS_6": "100",
"SPEED_NEGATIVE_MPS": "9",
"SPEED_0_TO_5_MPS": "157",
"SPEED_5_TO_10_MPS": "69",
"SPEED_15_TO_20_MPS": "15",
"SPEED_20_TO_25_MPS": "3",
"SPEED_25_TO_30_MPS": "5",
"CURVE_RADIUS_UNKNOWN": "83",
"CURVE_RADIUS_0_TO_100_M": "62",
"CURVE_RADIUS_100_TO_250_M": "20",
"CURVE_RADIUS_250_TO_500_M": "12",
"CURVE_RADIUS_500_TO_1000_M": "52",
"CURVE_RADIUS_1000_TO_2000_M": "11",
"CURVE_RADIUS_2000_TO_5000_M": "37",
"CURVE_RADIUS_5000_TO_10000_M": "5",
"CURVE_RADIUS_10000_TO_100000_M": "3",
"CURVE_RADIUS_100000_OR_ABOVE_M": "0",
"GPS_FUSION_ON_S": "288",
"GPS_FIX_ON_S": "288",
"SATELLITE_RANGE_13_AND_UP_S": "288",
"CELL_CONNECTED_S": "288"
"odometry_m": {
"autosteer_on": {
"ROAD_CLASS_UNKNOWN": "0.000000",
"ROAD_CLASS_1": "1700.000000",
"ROAD_CLASS_2": "0.000000",
"ROAD_CLASS_3": "0.000000",
"ROAD_CLASS_4": "0.000000",
"ROAD_CLASS_5": "0.000000",
"ROAD_CLASS_6": "0.000000",
"SPEED_UNKNOWN": "0.000000",
"SPEED_NEGATIVE_MPS": "0.000000",
"SPEED_0_TO_5_MPS": "0.000000",
"SPEED_5_TO_10_MPS": "0.000000",
"SPEED_10_TO_15_MPS": "0.000000",
"SPEED_15_TO_20_MPS": "0.000000",
"SPEED_20_TO_25_MPS": "0.000000",
"SPEED_25_TO_30_MPS": "1700.000000",
"SPEED_30_TO_35_MPS": "0.000000",
"SPEED_35_TO_40_MPS": "0.000000",
"SPEED_40_TO_45_MPS": "0.000000",
"SPEED_45_TO_50_MPS": "0.000000",
"SPEED_50_OR_ABOVE_MPS": "0.000000",
"CURVE_RADIUS_UNKNOWN": "0.000000",
"CURVE_RADIUS_0_TO_100_M": "0.000000",
"CURVE_RADIUS_100_TO_250_M": "0.000000",
"CURVE_RADIUS_250_TO_500_M": "0.000000",
"CURVE_RADIUS_500_TO_1000_M": "0.000000",
"CURVE_RADIUS_1000_TO_2000_M": "0.000000",
"CURVE_RADIUS_2000_TO_5000_M": "0.000000",
"CURVE_RADIUS_5000_TO_10000_M": "0.000000",
"CURVE_RADIUS_10000_TO_100000_M": "1700.000000",
"CURVE_RADIUS_100000_OR_ABOVE_M": "0.000000",
"GPS_FUSION_OFF_M": "0.000000",
"GPS_FUSION_ON_M": "1700.000000",
"GPS_FIX_OFF_M": "0.000000",
"GPS_FIX_ON_M": "1700.000000",
"SATELLITE_RANGE_0_TO_3_M": "0.000000",
"SATELLITE_RANGE_4_TO_7_M": "0.000000",
"SATELLITE_RANGE_8_TO_12_M": "0.000000",
"SATELLITE_RANGE_13_AND_UP_M": "1700.000000",
"CELL_NOT_CONNECTED_M": "0.000000",
"CELL_CONNECTED_M": "1700.000000"
"ROAD_CLASS_1": "0.000000",
"ROAD_CLASS_4": "1300.000000",
"SPEED_20_TO_25_MPS": "1300.000000",
"SPEED_25_TO_30_MPS": "0.000000",
"CURVE_RADIUS_250_TO_500_M": "1300.000000",
"CURVE_RADIUS_10000_TO_100000_M": "0.000000",
"GPS_FUSION_ON_M": "1300.000000",
"GPS_FIX_ON_M": "1300.000000",
"SATELLITE_RANGE_13_AND_UP_M": "1300.000000",
"CELL_CONNECTED_M": "1300.000000"
"ROAD_CLASS_1": "600.000000",
"ROAD_CLASS_4": "1900.000000",
"ROAD_CLASS_6": "99.500000",
"SPEED_0_TO_5_MPS": "1500.000000",
"SPEED_5_TO_10_MPS": "99.500000",
"SPEED_10_TO_15_MPS": "400.000000",
"SPEED_25_TO_30_MPS": "600.000000",
"CURVE_RADIUS_0_TO_100_M": "900.500000",
"CURVE_RADIUS_100_TO_250_M": "99.500000",
"CURVE_RADIUS_1000_TO_2000_M": "1000.000000",
"CURVE_RADIUS_2000_TO_5000_M": "599.500000",
"GPS_FUSION_ON_M": "2599.500000",
"GPS_FIX_ON_M": "2599.500000",
"SATELLITE_RANGE_13_AND_UP_M": "2599.500000",
"CELL_CONNECTED_M": "2599.500000"
"acc": {
"time_s": {
"acc_on": {
"ROAD_CLASS_4": "28",
"SPEED_15_TO_20_MPS": "14",
"CURVE_RADIUS_UNKNOWN": "1",
"CURVE_RADIUS_0_TO_100_M": "4",
"acc_available": {
"ROAD_CLASS_UNKNOWN": "2",
"ROAD_CLASS_1": "7",
"ROAD_CLASS_4": "150",
"ROAD_CLASS_6": "51",
"SPEED_0_TO_5_MPS": "8",
"SPEED_5_TO_10_MPS": "67",
"SPEED_10_TO_15_MPS": "56",
"SPEED_15_TO_20_MPS": "48",
"SPEED_20_TO_25_MPS": "15",
"SPEED_25_TO_30_MPS": "14",
"CURVE_RADIUS_UNKNOWN": "31",
"CURVE_RADIUS_0_TO_100_M": "6",
"CURVE_RADIUS_100_TO_250_M": "25",
"CURVE_RADIUS_250_TO_500_M": "21",
"CURVE_RADIUS_500_TO_1000_M": "37",
"CURVE_RADIUS_1000_TO_2000_M": "32",
"CURVE_RADIUS_2000_TO_5000_M": "25",
"CURVE_RADIUS_5000_TO_10000_M": "12",
"CURVE_RADIUS_10000_TO_100000_M": "15",
"acc_unavailable": {
"ROAD_CLASS_UNKNOWN": "5",
"ROAD_CLASS_1": "0",
"ROAD_CLASS_4": "117",
"ROAD_CLASS_6": "48",
"SPEED_0_TO_5_MPS": "151",
"SPEED_5_TO_10_MPS": "11",
"SPEED_15_TO_20_MPS": "0",
"SPEED_20_TO_25_MPS": "0",
"SPEED_25_TO_30_MPS": "0",
"CURVE_RADIUS_UNKNOWN": "51",
"CURVE_RADIUS_0_TO_100_M": "52",
"CURVE_RADIUS_100_TO_250_M": "1",
"CURVE_RADIUS_250_TO_500_M": "0",
"CURVE_RADIUS_500_TO_1000_M": "32",
"CURVE_RADIUS_1000_TO_2000_M": "0",
"CURVE_RADIUS_2000_TO_5000_M": "32",
"CURVE_RADIUS_5000_TO_10000_M": "0",
"CURVE_RADIUS_10000_TO_100000_M": "0",
"odometry_m": {
"acc_on": {
"acc_available": {
"ROAD_CLASS_4": "1700.000000",
"ROAD_CLASS_4": "1500.000000",
"alc": {
"aborted": "0",
"completed": "0",
"initiated": "0",
"requested": "0"
"histograms": {
"autosteer": {
"on": {
"GPS_QUALITY_DURATION": {
"BUCKET_UNITS": "categories",
"VALUE_UNITS": "seconds",
"NUM_BUCKETS": "7",
"VALUES": {
"NO_COMMUNICATION": "0",
"OUTPUT_UNAVAILABLE": "0",
"UNKNOWN": "0",
"DEAD_RECKONING_ONLY": "0",
"VISIBLE_POORLY": "0",
"ROAD": "0",
"LANE": "101"
"GPS_QUALITY_DISTANCE": {
"VALUE_UNITS": "meters",
"NUM_BUCKETS": "7",
"VALUES": {
"NO_COMMUNICATION": "0.000000",
"OUTPUT_UNAVAILABLE": "0.000000",
"UNKNOWN": "0.000000",
"DEAD_RECKONING_ONLY": "0.000000",
"VISIBLE_POORLY": "0.000000",
"ROAD": "0.000000",
"LANE": "1700.000000"
"ACTIVE_DURATION": {
"BUCKET_UNITS": "minutes",
"VALUE_UNITS": "counts",
"NUM_BUCKETS": "121",
"BUCKET_MIN": "0",
"BUCKET_MAX": "121",
"VALUES": {
"min": "0",
"0": "1",
"1": "1",
"max": "0"
"ACTIVE_DISTANCE": {
"BUCKET_UNITS": "kilometers",
"BUCKET_MIN": "0",
"VALUES": {
"min": "0",
"0": "1",
"1": "1",
"max": "0"
"available": {
"NUM_BUCKETS": "7",
"VALUES": {
"UNKNOWN": "0",
"ROAD": "0",
"LANE": "100"
"NUM_BUCKETS": "7",
"VALUES": {
"ROAD": "0.000000",
"LANE": "1300.000000"
"unavailable": {
"NUM_BUCKETS": "7",
"VALUES": {
"UNKNOWN": "0",
"ROAD": "0",
"LANE": "288"
"NUM_BUCKETS": "7",
"VALUES": {
"ROAD": "0.000000",
"LANE": "2599.500000"
"acc": {
"on": {
"NUM_BUCKETS": "7",
"VALUES": {
"UNKNOWN": "0",
"ROAD": "0",
"LANE": "101"
"NUM_BUCKETS": "7",
"VALUES": {
"ROAD": "0.000000",
"BUCKET_MIN": "0",
"VALUES": {
"min": "0",
"0": "3",
"1": "1",
"max": "0"
"BUCKET_MIN": "0",
"VALUES": {
"min": "0",
"0": "3",
"1": "1",
"max": "0"
"available": {
"NUM_BUCKETS": "7",
"VALUES": {
"UNKNOWN": "0",
"ROAD": "0",
"LANE": "100"
"NUM_BUCKETS": "7",
"VALUES": {
"ROAD": "0.000000",
"unavailable": {
"NUM_BUCKETS": "7",
"VALUES": {
"UNKNOWN": "0",
"ROAD": "0",
"LANE": "288"
"NUM_BUCKETS": "7",
"VALUES": {
"ROAD": "0.000000",
"driver_interventions": {
"steering": {
"total": "1",
"ROAD_CLASS_4": "1",
"SPEED_15_TO_20_MPS": "1",
"CURVE_RADIUS_0_TO_100_M": "1",
"CURVE_RADIUS_500_TO_1000_M": "0",
"CURVE_RADIUS_2000_TO_5000_M": "0",
"CIPV_NOT_ASSOCIATED": "1",
"CIPV_ASSOCIATED": "0",
"STEERING_WHEEL_SPEED_0_TO_100_DEGPS": "1",
"STEERING_WHEEL_SPEED_100_TO_200_DEGPS": "0",
"STEERING_WHEEL_SPEED_200_TO_300_DEGPS": "0",
"STEERING_WHEEL_SPEED_300_TO_400_DEGPS": "0",
"STEERING_WHEEL_SPEED_400_TO_500_DEGPS": "0",
"STEERING_WHEEL_SPEED_500_DEGPS_AND_UP": "0"
"braking": {
"total": "0",
"ROAD_CLASS_4": "0",
"CIPV_NOT_ASSOCIATED": "0",
"BRAKING_1_TO_MINUS_1_M_S_SQ": "0",
"BRAKING_MINUS_1_TO_MINUS_2_M_S_SQ": "0",
"BRAKING_MINUS_2_TO_MINUS_4_M_S_SQ": "0",
"BRAKING_MINUS_4_TO_MINUS_6_M_S_SQ": "0",
"BRAKING_MINUS_6_TO_MINUS_8_M_S_SQ": "0",
"BRAKING_MINUS_8_M_S_SQ_AND_BELOW": "0"
"stalk": {
"total": "1",
"CURVE_RADIUS_1000_TO_2000_M": "1",
"system_interventions": {
"EPAS_EAC_DENIED": "0",
"COMPONENT_MIA": "0",
"CRUISE_FAULT": "0",
"CID_SWITCH_DISABLED": "0",
"DRIVING_OFF_NAV": "0",
"HEALTH_MONITOR": "0",
"VEHICLE_SPEED_ABOVE_MAX": "0",
"FOLLOWER_OUTPUT_INVALID": "0",
"PLANNER_OUTPUT_INVALID": "0",
"EPAS_ERROR_CODE": "0",
"CAMERA_FAILSAFES": "0",
"ACC_CANCEL": "0",
"SIDE_COLLISION_IMMINENT": "0",
"TRAILER_MODE_ACTIVATION": "0",
"CAMERA_WATCHDOG": "0",
"CAMERA_MSG_MIA": "0",
"ME_MAIN_STATE": "0",
"APP_ME_STATE": "0"
"ap_unavailability": {
"NONE": {
"time_s": {
"ROAD_CLASS_1": "1",
"ROAD_CLASS_4": "10",
"ROAD_CLASS_6": "0"
"odometry_m": {
"ROAD_CLASS_4": "400.000000",
"EPAS_EAC_DENIED": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"COMPONENT_MIA": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"COMPONENT_NOT_READY": {
"time_s": {
"ROAD_CLASS_4": "32",
"ROAD_CLASS_6": "0"
"odometry_m": {
"ROAD_CLASS_4": "599.500000",
"CRUISE_FAULT": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"VEHICLE_NOT_IN_DRIVE": {
"time_s": {
"ROAD_CLASS_6": "11"
"odometry_m": {
"VEHICLE_SPEED_ABOVE_MAX": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"STEERING_LIMITS_EXCEEDED": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"CAMERA_FAILSAFES": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"TRAILER_MODE_ACTIVE": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"CAM_WATCHDOG": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"HK_TW_RESTRICTED": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"CAM_MSG_MIA": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"EAC_REQUEST_TIMEOUT": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"USER_STRIKEOUT": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"ME_MAIN_STATE_NOT_VISION": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"CONTROL_OUTSIDE_LIMITS": {
"time_s": {
"ROAD_CLASS_UNKNOWN": "1",
"ROAD_CLASS_4": "9",
"ROAD_CLASS_6": "23"
"odometry_m": {
"CONTROL_PATH_UNHEALTHY": {
"time_s": {
"ROAD_CLASS_6": "4"
"odometry_m": {
"CONTROL_SOLVER_UNHEALTHY": {
"time_s": {
"ROAD_CLASS_4": "2",
"ROAD_CLASS_6": "2"
"odometry_m": {
"SPEED_LIMIT_EXCEEDED": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"NOT_ON_HIGHWAY": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"VEHICLE_SPEED_ABOVE_MAX_HYST": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"ROAD_ESTIMATOR_NOT_ALLOWED": {
"time_s": {
"ROAD_CLASS_UNKNOWN": "3",
"ROAD_CLASS_4": "118",
"ROAD_CLASS_6": "58"
"odometry_m": {
"ROAD_CLASS_4": "900.500000",
"UNKOWN": {
"time_s": {
"ROAD_CLASS_6": "0"
"odometry_m": {
"config": {
"version": "1.2",
"lc_enable": "true",
"autopilot_car": "true",
"radar_type": "bosch",
"timezone": "Japan\/Tokyo",
"ISO_country_code": "392"
"trip_log": "\/telemetry\/trip_log.pb"
no, it's tweaked some more and the size changed a little bit.@verygreen is the main camera NN the same as in .40?
BTW the autopilot track log got extended again. A lot more extra info and now it contains some sort of a binary log at the end that grows as you travel. 6 byte chunks are added per some unit of travel/time?
sample of a new trip log:
Code:{ "snapshot-version": "0.3", "wall-time": "1508987636850212162", "monotonic-time": "1185683024834", "sha1": "a88c8d597f1c5eb1", "requester": "autopilot-trip-log", "faux-board-id": "2e563f1d-7b53-4a66-afc8-2c32b4d9a672", "request-clock-type": "monotonic", "request-trigger-time": "1185682931785", "boot-sec-info": "0x00000002", "vehicle-type": "M3-RHD", "hardware-type": "HW2.5", "product-release": "2017.42 (develop-2017.42-6749-a88c8d597f)", "cameras": { "main": { "pixel_format": "RAW12_NVIDIA", "color_filter": "RCCC", "width": "1280", "height": "960" }, "narrow": { "pixel_format": "RAW12_NVIDIA", "color_filter": "RCCC", "width": "1280", "height": "960" }, "fisheye": { "pixel_format": "RAW12_NVIDIA", "color_filter": "RCCC", "width": "1280", "height": "960" }, "leftpillar": { "pixel_format": "RAW12_NVIDIA", "color_filter": "RCCC", "width": "1280", "height": "960" }, "rightpillar": { "pixel_format": "RAW12_NVIDIA", "color_filter": "RCCC", "width": "1280", "height": "960" }, "leftrepeater": { "pixel_format": "RAW12_NVIDIA", "color_filter": "RCCC", "width": "1280", "height": "960" }, "rightrepeater": { "pixel_format": "RAW12_NVIDIA", "color_filter": "RCCC", "width": "1280", "height": "960" }, "backup": { "pixel_format": "UYVY", "color_filter": "RGGB", "width": "1160", "height": "720" } }, "entries": { "autosteer": { "time_s": { "autosteer_on": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "77", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "24", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0", "SPEED_UNKNOWN": "0", "SPEED_NEGATIVE_MPS": "0", "SPEED_0_TO_5_MPS": "0", "SPEED_5_TO_10_MPS": "0", "SPEED_10_TO_15_MPS": "0", "SPEED_15_TO_20_MPS": "9", "SPEED_20_TO_25_MPS": "11", "SPEED_25_TO_30_MPS": "80", "SPEED_30_TO_35_MPS": "0", "SPEED_35_TO_40_MPS": "0", "SPEED_40_TO_45_MPS": "0", "SPEED_45_TO_50_MPS": "0", "SPEED_50_OR_ABOVE_MPS": "0", "CURVE_RADIUS_UNKNOWN": "0", "CURVE_RADIUS_0_TO_100_M": "0", "CURVE_RADIUS_100_TO_250_M": "0", "CURVE_RADIUS_250_TO_500_M": "5", "CURVE_RADIUS_500_TO_1000_M": "4", "CURVE_RADIUS_1000_TO_2000_M": "17", "CURVE_RADIUS_2000_TO_5000_M": "36", "CURVE_RADIUS_5000_TO_10000_M": "22", "CURVE_RADIUS_10000_TO_100000_M": "11", "CURVE_RADIUS_100000_OR_ABOVE_M": "3", "GPS_FUSION_OFF_S": "0", "GPS_FUSION_ON_S": "101", "GPS_FIX_OFF_S": "0", "GPS_FIX_ON_S": "101", "SATELLITE_RANGE_0_TO_3_S": "0", "SATELLITE_RANGE_4_TO_7_S": "0", "SATELLITE_RANGE_8_TO_12_S": "0", "SATELLITE_RANGE_13_AND_UP_S": "101", "CELL_NOT_CONNECTED_S": "0", "CELL_CONNECTED_S": "101" }, "autosteer_available": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "2", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "97", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0", "SPEED_UNKNOWN": "0", "SPEED_NEGATIVE_MPS": "0", "SPEED_0_TO_5_MPS": "2", "SPEED_5_TO_10_MPS": "9", "SPEED_10_TO_15_MPS": "28", "SPEED_15_TO_20_MPS": "37", "SPEED_20_TO_25_MPS": "12", "SPEED_25_TO_30_MPS": "9", "SPEED_30_TO_35_MPS": "0", "SPEED_35_TO_40_MPS": "0", "SPEED_40_TO_45_MPS": "0", "SPEED_45_TO_50_MPS": "0", "SPEED_50_OR_ABOVE_MPS": "0", "CURVE_RADIUS_UNKNOWN": "0", "CURVE_RADIUS_0_TO_100_M": "0", "CURVE_RADIUS_100_TO_250_M": "6", "CURVE_RADIUS_250_TO_500_M": "9", "CURVE_RADIUS_500_TO_1000_M": "18", "CURVE_RADIUS_1000_TO_2000_M": "21", "CURVE_RADIUS_2000_TO_5000_M": "20", "CURVE_RADIUS_5000_TO_10000_M": "7", "CURVE_RADIUS_10000_TO_100000_M": "11", "CURVE_RADIUS_100000_OR_ABOVE_M": "3", "GPS_FUSION_OFF_S": "0", "GPS_FUSION_ON_S": "100", "GPS_FIX_OFF_S": "0", "GPS_FIX_ON_S": "100", "SATELLITE_RANGE_0_TO_3_S": "0", "SATELLITE_RANGE_4_TO_7_S": "0", "SATELLITE_RANGE_8_TO_12_S": "0", "SATELLITE_RANGE_13_AND_UP_S": "100", "CELL_NOT_CONNECTED_S": "0", "CELL_CONNECTED_S": "100" }, "autosteer_unavailable": { "ROAD_CLASS_UNKNOWN": "8", "ROAD_CLASS_1": "5", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "174", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "100", "SPEED_UNKNOWN": "0", "SPEED_NEGATIVE_MPS": "9", "SPEED_0_TO_5_MPS": "157", "SPEED_5_TO_10_MPS": "69", "SPEED_10_TO_15_MPS": "28", "SPEED_15_TO_20_MPS": "15", "SPEED_20_TO_25_MPS": "3", "SPEED_25_TO_30_MPS": "5", "SPEED_30_TO_35_MPS": "0", "SPEED_35_TO_40_MPS": "0", "SPEED_40_TO_45_MPS": "0", "SPEED_45_TO_50_MPS": "0", "SPEED_50_OR_ABOVE_MPS": "0", "CURVE_RADIUS_UNKNOWN": "83", "CURVE_RADIUS_0_TO_100_M": "62", "CURVE_RADIUS_100_TO_250_M": "20", "CURVE_RADIUS_250_TO_500_M": "12", "CURVE_RADIUS_500_TO_1000_M": "52", "CURVE_RADIUS_1000_TO_2000_M": "11", "CURVE_RADIUS_2000_TO_5000_M": "37", "CURVE_RADIUS_5000_TO_10000_M": "5", "CURVE_RADIUS_10000_TO_100000_M": "3", "CURVE_RADIUS_100000_OR_ABOVE_M": "0", "GPS_FUSION_OFF_S": "0", "GPS_FUSION_ON_S": "288", "GPS_FIX_OFF_S": "0", "GPS_FIX_ON_S": "288", "SATELLITE_RANGE_0_TO_3_S": "0", "SATELLITE_RANGE_4_TO_7_S": "0", "SATELLITE_RANGE_8_TO_12_S": "0", "SATELLITE_RANGE_13_AND_UP_S": "288", "CELL_NOT_CONNECTED_S": "0", "CELL_CONNECTED_S": "288" } }, "odometry_m": { "autosteer_on": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "1700.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000", "SPEED_UNKNOWN": "0.000000", "SPEED_NEGATIVE_MPS": "0.000000", "SPEED_0_TO_5_MPS": "0.000000", "SPEED_5_TO_10_MPS": "0.000000", "SPEED_10_TO_15_MPS": "0.000000", "SPEED_15_TO_20_MPS": "0.000000", "SPEED_20_TO_25_MPS": "0.000000", "SPEED_25_TO_30_MPS": "1700.000000", "SPEED_30_TO_35_MPS": "0.000000", "SPEED_35_TO_40_MPS": "0.000000", "SPEED_40_TO_45_MPS": "0.000000", "SPEED_45_TO_50_MPS": "0.000000", "SPEED_50_OR_ABOVE_MPS": "0.000000", "CURVE_RADIUS_UNKNOWN": "0.000000", "CURVE_RADIUS_0_TO_100_M": "0.000000", "CURVE_RADIUS_100_TO_250_M": "0.000000", "CURVE_RADIUS_250_TO_500_M": "0.000000", "CURVE_RADIUS_500_TO_1000_M": "0.000000", "CURVE_RADIUS_1000_TO_2000_M": "0.000000", "CURVE_RADIUS_2000_TO_5000_M": "0.000000", "CURVE_RADIUS_5000_TO_10000_M": "0.000000", "CURVE_RADIUS_10000_TO_100000_M": "1700.000000", "CURVE_RADIUS_100000_OR_ABOVE_M": "0.000000", "GPS_FUSION_OFF_M": "0.000000", "GPS_FUSION_ON_M": "1700.000000", "GPS_FIX_OFF_M": "0.000000", "GPS_FIX_ON_M": "1700.000000", "SATELLITE_RANGE_0_TO_3_M": "0.000000", "SATELLITE_RANGE_4_TO_7_M": "0.000000", "SATELLITE_RANGE_8_TO_12_M": "0.000000", "SATELLITE_RANGE_13_AND_UP_M": "1700.000000", "CELL_NOT_CONNECTED_M": "0.000000", "CELL_CONNECTED_M": "1700.000000" }, "autosteer_available": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "1300.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000", "SPEED_UNKNOWN": "0.000000", "SPEED_NEGATIVE_MPS": "0.000000", "SPEED_0_TO_5_MPS": "0.000000", "SPEED_5_TO_10_MPS": "0.000000", "SPEED_10_TO_15_MPS": "0.000000", "SPEED_15_TO_20_MPS": "0.000000", "SPEED_20_TO_25_MPS": "1300.000000", "SPEED_25_TO_30_MPS": "0.000000", "SPEED_30_TO_35_MPS": "0.000000", "SPEED_35_TO_40_MPS": "0.000000", "SPEED_40_TO_45_MPS": "0.000000", "SPEED_45_TO_50_MPS": "0.000000", "SPEED_50_OR_ABOVE_MPS": "0.000000", "CURVE_RADIUS_UNKNOWN": "0.000000", "CURVE_RADIUS_0_TO_100_M": "0.000000", "CURVE_RADIUS_100_TO_250_M": "0.000000", "CURVE_RADIUS_250_TO_500_M": "1300.000000", "CURVE_RADIUS_500_TO_1000_M": "0.000000", "CURVE_RADIUS_1000_TO_2000_M": "0.000000", "CURVE_RADIUS_2000_TO_5000_M": "0.000000", "CURVE_RADIUS_5000_TO_10000_M": "0.000000", "CURVE_RADIUS_10000_TO_100000_M": "0.000000", "CURVE_RADIUS_100000_OR_ABOVE_M": "0.000000", "GPS_FUSION_OFF_M": "0.000000", "GPS_FUSION_ON_M": "1300.000000", "GPS_FIX_OFF_M": "0.000000", "GPS_FIX_ON_M": "1300.000000", "SATELLITE_RANGE_0_TO_3_M": "0.000000", "SATELLITE_RANGE_4_TO_7_M": "0.000000", "SATELLITE_RANGE_8_TO_12_M": "0.000000", "SATELLITE_RANGE_13_AND_UP_M": "1300.000000", "CELL_NOT_CONNECTED_M": "0.000000", "CELL_CONNECTED_M": "1300.000000" }, "autosteer_unavailable": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "600.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "1900.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "99.500000", "SPEED_UNKNOWN": "0.000000", "SPEED_NEGATIVE_MPS": "0.000000", "SPEED_0_TO_5_MPS": "1500.000000", "SPEED_5_TO_10_MPS": "99.500000", "SPEED_10_TO_15_MPS": "400.000000", "SPEED_15_TO_20_MPS": "0.000000", "SPEED_20_TO_25_MPS": "0.000000", "SPEED_25_TO_30_MPS": "600.000000", "SPEED_30_TO_35_MPS": "0.000000", "SPEED_35_TO_40_MPS": "0.000000", "SPEED_40_TO_45_MPS": "0.000000", "SPEED_45_TO_50_MPS": "0.000000", "SPEED_50_OR_ABOVE_MPS": "0.000000", "CURVE_RADIUS_UNKNOWN": "0.000000", "CURVE_RADIUS_0_TO_100_M": "900.500000", "CURVE_RADIUS_100_TO_250_M": "99.500000", "CURVE_RADIUS_250_TO_500_M": "0.000000", "CURVE_RADIUS_500_TO_1000_M": "0.000000", "CURVE_RADIUS_1000_TO_2000_M": "1000.000000", "CURVE_RADIUS_2000_TO_5000_M": "599.500000", "CURVE_RADIUS_5000_TO_10000_M": "0.000000", "CURVE_RADIUS_10000_TO_100000_M": "0.000000", "CURVE_RADIUS_100000_OR_ABOVE_M": "0.000000", "GPS_FUSION_OFF_M": "0.000000", "GPS_FUSION_ON_M": "2599.500000", "GPS_FIX_OFF_M": "0.000000", "GPS_FIX_ON_M": "2599.500000", "SATELLITE_RANGE_0_TO_3_M": "0.000000", "SATELLITE_RANGE_4_TO_7_M": "0.000000", "SATELLITE_RANGE_8_TO_12_M": "0.000000", "SATELLITE_RANGE_13_AND_UP_M": "2599.500000", "CELL_NOT_CONNECTED_M": "0.000000", "CELL_CONNECTED_M": "2599.500000" } } }, "acc": { "time_s": { "acc_on": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "77", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "28", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0", "SPEED_UNKNOWN": "0", "SPEED_NEGATIVE_MPS": "0", "SPEED_0_TO_5_MPS": "0", "SPEED_5_TO_10_MPS": "0", "SPEED_10_TO_15_MPS": "0", "SPEED_15_TO_20_MPS": "14", "SPEED_20_TO_25_MPS": "11", "SPEED_25_TO_30_MPS": "80", "SPEED_30_TO_35_MPS": "0", "SPEED_35_TO_40_MPS": "0", "SPEED_40_TO_45_MPS": "0", "SPEED_45_TO_50_MPS": "0", "SPEED_50_OR_ABOVE_MPS": "0", "CURVE_RADIUS_UNKNOWN": "1", "CURVE_RADIUS_0_TO_100_M": "4", "CURVE_RADIUS_100_TO_250_M": "0", "CURVE_RADIUS_250_TO_500_M": "5", "CURVE_RADIUS_500_TO_1000_M": "4", "CURVE_RADIUS_1000_TO_2000_M": "17", "CURVE_RADIUS_2000_TO_5000_M": "36", "CURVE_RADIUS_5000_TO_10000_M": "22", "CURVE_RADIUS_10000_TO_100000_M": "11", "CURVE_RADIUS_100000_OR_ABOVE_M": "3" }, "acc_available": { "ROAD_CLASS_UNKNOWN": "2", "ROAD_CLASS_1": "7", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "150", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "51", "SPEED_UNKNOWN": "0", "SPEED_NEGATIVE_MPS": "0", "SPEED_0_TO_5_MPS": "8", "SPEED_5_TO_10_MPS": "67", "SPEED_10_TO_15_MPS": "56", "SPEED_15_TO_20_MPS": "48", "SPEED_20_TO_25_MPS": "15", "SPEED_25_TO_30_MPS": "14", "SPEED_30_TO_35_MPS": "0", "SPEED_35_TO_40_MPS": "0", "SPEED_40_TO_45_MPS": "0", "SPEED_45_TO_50_MPS": "0", "SPEED_50_OR_ABOVE_MPS": "0", "CURVE_RADIUS_UNKNOWN": "31", "CURVE_RADIUS_0_TO_100_M": "6", "CURVE_RADIUS_100_TO_250_M": "25", "CURVE_RADIUS_250_TO_500_M": "21", "CURVE_RADIUS_500_TO_1000_M": "37", "CURVE_RADIUS_1000_TO_2000_M": "32", "CURVE_RADIUS_2000_TO_5000_M": "25", "CURVE_RADIUS_5000_TO_10000_M": "12", "CURVE_RADIUS_10000_TO_100000_M": "15", "CURVE_RADIUS_100000_OR_ABOVE_M": "3" }, "acc_unavailable": { "ROAD_CLASS_UNKNOWN": "5", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "117", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "48", "SPEED_UNKNOWN": "0", "SPEED_NEGATIVE_MPS": "9", "SPEED_0_TO_5_MPS": "151", "SPEED_5_TO_10_MPS": "11", "SPEED_10_TO_15_MPS": "0", "SPEED_15_TO_20_MPS": "0", "SPEED_20_TO_25_MPS": "0", "SPEED_25_TO_30_MPS": "0", "SPEED_30_TO_35_MPS": "0", "SPEED_35_TO_40_MPS": "0", "SPEED_40_TO_45_MPS": "0", "SPEED_45_TO_50_MPS": "0", "SPEED_50_OR_ABOVE_MPS": "0", "CURVE_RADIUS_UNKNOWN": "51", "CURVE_RADIUS_0_TO_100_M": "52", "CURVE_RADIUS_100_TO_250_M": "1", "CURVE_RADIUS_250_TO_500_M": "0", "CURVE_RADIUS_500_TO_1000_M": "32", "CURVE_RADIUS_1000_TO_2000_M": "0", "CURVE_RADIUS_2000_TO_5000_M": "32", "CURVE_RADIUS_5000_TO_10000_M": "0", "CURVE_RADIUS_10000_TO_100000_M": "0", "CURVE_RADIUS_100000_OR_ABOVE_M": "0" } }, "odometry_m": { "acc_on": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "1700.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000", "SPEED_UNKNOWN": "0.000000", "SPEED_NEGATIVE_MPS": "0.000000", "SPEED_0_TO_5_MPS": "0.000000", "SPEED_5_TO_10_MPS": "0.000000", "SPEED_10_TO_15_MPS": "0.000000", "SPEED_15_TO_20_MPS": "0.000000", "SPEED_20_TO_25_MPS": "0.000000", "SPEED_25_TO_30_MPS": "1700.000000", "SPEED_30_TO_35_MPS": "0.000000", "SPEED_35_TO_40_MPS": "0.000000", "SPEED_40_TO_45_MPS": "0.000000", "SPEED_45_TO_50_MPS": "0.000000", "SPEED_50_OR_ABOVE_MPS": "0.000000", "CURVE_RADIUS_UNKNOWN": "0.000000", "CURVE_RADIUS_0_TO_100_M": "0.000000", "CURVE_RADIUS_100_TO_250_M": "0.000000", "CURVE_RADIUS_250_TO_500_M": "0.000000", "CURVE_RADIUS_500_TO_1000_M": "0.000000", "CURVE_RADIUS_1000_TO_2000_M": "0.000000", "CURVE_RADIUS_2000_TO_5000_M": "0.000000", "CURVE_RADIUS_5000_TO_10000_M": "0.000000", "CURVE_RADIUS_10000_TO_100000_M": "1700.000000", "CURVE_RADIUS_100000_OR_ABOVE_M": "0.000000" }, "acc_available": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "600.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "1700.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "99.500000", "SPEED_UNKNOWN": "0.000000", "SPEED_NEGATIVE_MPS": "0.000000", "SPEED_0_TO_5_MPS": "0.000000", "SPEED_5_TO_10_MPS": "99.500000", "SPEED_10_TO_15_MPS": "400.000000", "SPEED_15_TO_20_MPS": "0.000000", "SPEED_20_TO_25_MPS": "1300.000000", "SPEED_25_TO_30_MPS": "600.000000", "SPEED_30_TO_35_MPS": "0.000000", "SPEED_35_TO_40_MPS": "0.000000", "SPEED_40_TO_45_MPS": "0.000000", "SPEED_45_TO_50_MPS": "0.000000", "SPEED_50_OR_ABOVE_MPS": "0.000000", "CURVE_RADIUS_UNKNOWN": "0.000000", "CURVE_RADIUS_0_TO_100_M": "0.000000", "CURVE_RADIUS_100_TO_250_M": "99.500000", "CURVE_RADIUS_250_TO_500_M": "1300.000000", "CURVE_RADIUS_500_TO_1000_M": "0.000000", "CURVE_RADIUS_1000_TO_2000_M": "1000.000000", "CURVE_RADIUS_2000_TO_5000_M": "0.000000", "CURVE_RADIUS_5000_TO_10000_M": "0.000000", "CURVE_RADIUS_10000_TO_100000_M": "0.000000", "CURVE_RADIUS_100000_OR_ABOVE_M": "0.000000" }, "acc_unavailable": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "1500.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000", "SPEED_UNKNOWN": "0.000000", "SPEED_NEGATIVE_MPS": "0.000000", "SPEED_0_TO_5_MPS": "1500.000000", "SPEED_5_TO_10_MPS": "0.000000", "SPEED_10_TO_15_MPS": "0.000000", "SPEED_15_TO_20_MPS": "0.000000", "SPEED_20_TO_25_MPS": "0.000000", "SPEED_25_TO_30_MPS": "0.000000", "SPEED_30_TO_35_MPS": "0.000000", "SPEED_35_TO_40_MPS": "0.000000", "SPEED_40_TO_45_MPS": "0.000000", "SPEED_45_TO_50_MPS": "0.000000", "SPEED_50_OR_ABOVE_MPS": "0.000000", "CURVE_RADIUS_UNKNOWN": "0.000000", "CURVE_RADIUS_0_TO_100_M": "900.500000", "CURVE_RADIUS_100_TO_250_M": "0.000000", "CURVE_RADIUS_250_TO_500_M": "0.000000", "CURVE_RADIUS_500_TO_1000_M": "0.000000", "CURVE_RADIUS_1000_TO_2000_M": "0.000000", "CURVE_RADIUS_2000_TO_5000_M": "599.500000", "CURVE_RADIUS_5000_TO_10000_M": "0.000000", "CURVE_RADIUS_10000_TO_100000_M": "0.000000", "CURVE_RADIUS_100000_OR_ABOVE_M": "0.000000" } } }, "alc": { "aborted": "0", "completed": "0", "initiated": "0", "requested": "0" }, "histograms": { "autosteer": { "on": { "GPS_QUALITY_DURATION": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "seconds", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0", "OUTPUT_UNAVAILABLE": "0", "UNKNOWN": "0", "DEAD_RECKONING_ONLY": "0", "VISIBLE_POORLY": "0", "ROAD": "0", "LANE": "101" } }, "GPS_QUALITY_DISTANCE": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "meters", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0.000000", "OUTPUT_UNAVAILABLE": "0.000000", "UNKNOWN": "0.000000", "DEAD_RECKONING_ONLY": "0.000000", "VISIBLE_POORLY": "0.000000", "ROAD": "0.000000", "LANE": "1700.000000" } }, "ACTIVE_DURATION": { "BUCKET_UNITS": "minutes", "VALUE_UNITS": "counts", "NUM_BUCKETS": "121", "BUCKET_MIN": "0", "BUCKET_MAX": "121", "VALUES": { "min": "0", "0": "1", "1": "1", "max": "0" } }, "ACTIVE_DISTANCE": { "BUCKET_UNITS": "kilometers", "VALUE_UNITS": "counts", "NUM_BUCKETS": "121", "BUCKET_MIN": "0", "BUCKET_MAX": "121", "VALUES": { "min": "0", "0": "1", "1": "1", "max": "0" } } }, "available": { "GPS_QUALITY_DURATION": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "seconds", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0", "OUTPUT_UNAVAILABLE": "0", "UNKNOWN": "0", "DEAD_RECKONING_ONLY": "0", "VISIBLE_POORLY": "0", "ROAD": "0", "LANE": "100" } }, "GPS_QUALITY_DISTANCE": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "meters", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0.000000", "OUTPUT_UNAVAILABLE": "0.000000", "UNKNOWN": "0.000000", "DEAD_RECKONING_ONLY": "0.000000", "VISIBLE_POORLY": "0.000000", "ROAD": "0.000000", "LANE": "1300.000000" } } }, "unavailable": { "GPS_QUALITY_DURATION": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "seconds", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0", "OUTPUT_UNAVAILABLE": "0", "UNKNOWN": "0", "DEAD_RECKONING_ONLY": "0", "VISIBLE_POORLY": "0", "ROAD": "0", "LANE": "288" } }, "GPS_QUALITY_DISTANCE": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "meters", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0.000000", "OUTPUT_UNAVAILABLE": "0.000000", "UNKNOWN": "0.000000", "DEAD_RECKONING_ONLY": "0.000000", "VISIBLE_POORLY": "0.000000", "ROAD": "0.000000", "LANE": "2599.500000" } } } }, "acc": { "on": { "GPS_QUALITY_DURATION": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "seconds", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0", "OUTPUT_UNAVAILABLE": "0", "UNKNOWN": "0", "DEAD_RECKONING_ONLY": "0", "VISIBLE_POORLY": "0", "ROAD": "0", "LANE": "101" } }, "GPS_QUALITY_DISTANCE": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "meters", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0.000000", "OUTPUT_UNAVAILABLE": "0.000000", "UNKNOWN": "0.000000", "DEAD_RECKONING_ONLY": "0.000000", "VISIBLE_POORLY": "0.000000", "ROAD": "0.000000", "LANE": "1700.000000" } }, "ACTIVE_DURATION": { "BUCKET_UNITS": "minutes", "VALUE_UNITS": "counts", "NUM_BUCKETS": "121", "BUCKET_MIN": "0", "BUCKET_MAX": "121", "VALUES": { "min": "0", "0": "3", "1": "1", "max": "0" } }, "ACTIVE_DISTANCE": { "BUCKET_UNITS": "kilometers", "VALUE_UNITS": "counts", "NUM_BUCKETS": "121", "BUCKET_MIN": "0", "BUCKET_MAX": "121", "VALUES": { "min": "0", "0": "3", "1": "1", "max": "0" } } }, "available": { "GPS_QUALITY_DURATION": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "seconds", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0", "OUTPUT_UNAVAILABLE": "0", "UNKNOWN": "0", "DEAD_RECKONING_ONLY": "0", "VISIBLE_POORLY": "0", "ROAD": "0", "LANE": "100" } }, "GPS_QUALITY_DISTANCE": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "meters", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0.000000", "OUTPUT_UNAVAILABLE": "0.000000", "UNKNOWN": "0.000000", "DEAD_RECKONING_ONLY": "0.000000", "VISIBLE_POORLY": "0.000000", "ROAD": "0.000000", "LANE": "1300.000000" } } }, "unavailable": { "GPS_QUALITY_DURATION": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "seconds", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0", "OUTPUT_UNAVAILABLE": "0", "UNKNOWN": "0", "DEAD_RECKONING_ONLY": "0", "VISIBLE_POORLY": "0", "ROAD": "0", "LANE": "288" } }, "GPS_QUALITY_DISTANCE": { "BUCKET_UNITS": "categories", "VALUE_UNITS": "meters", "NUM_BUCKETS": "7", "VALUES": { "NO_COMMUNICATION": "0.000000", "OUTPUT_UNAVAILABLE": "0.000000", "UNKNOWN": "0.000000", "DEAD_RECKONING_ONLY": "0.000000", "VISIBLE_POORLY": "0.000000", "ROAD": "0.000000", "LANE": "2599.500000" } } } } }, "driver_interventions": { "steering": { "total": "1", "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "1", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0", "SPEED_UNKNOWN": "0", "SPEED_NEGATIVE_MPS": "0", "SPEED_0_TO_5_MPS": "0", "SPEED_5_TO_10_MPS": "0", "SPEED_10_TO_15_MPS": "0", "SPEED_15_TO_20_MPS": "1", "SPEED_20_TO_25_MPS": "0", "SPEED_25_TO_30_MPS": "0", "SPEED_30_TO_35_MPS": "0", "SPEED_35_TO_40_MPS": "0", "SPEED_40_TO_45_MPS": "0", "SPEED_45_TO_50_MPS": "0", "SPEED_50_OR_ABOVE_MPS": "0", "CURVE_RADIUS_UNKNOWN": "0", "CURVE_RADIUS_0_TO_100_M": "1", "CURVE_RADIUS_100_TO_250_M": "0", "CURVE_RADIUS_250_TO_500_M": "0", "CURVE_RADIUS_500_TO_1000_M": "0", "CURVE_RADIUS_1000_TO_2000_M": "0", "CURVE_RADIUS_2000_TO_5000_M": "0", "CURVE_RADIUS_5000_TO_10000_M": "0", "CURVE_RADIUS_10000_TO_100000_M": "0", "CURVE_RADIUS_100000_OR_ABOVE_M": "0", "CIPV_NOT_ASSOCIATED": "1", "CIPV_ASSOCIATED": "0", "STEERING_WHEEL_SPEED_0_TO_100_DEGPS": "1", "STEERING_WHEEL_SPEED_100_TO_200_DEGPS": "0", "STEERING_WHEEL_SPEED_200_TO_300_DEGPS": "0", "STEERING_WHEEL_SPEED_300_TO_400_DEGPS": "0", "STEERING_WHEEL_SPEED_400_TO_500_DEGPS": "0", "STEERING_WHEEL_SPEED_500_DEGPS_AND_UP": "0" }, "braking": { "total": "0", "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0", "SPEED_UNKNOWN": "0", "SPEED_NEGATIVE_MPS": "0", "SPEED_0_TO_5_MPS": "0", "SPEED_5_TO_10_MPS": "0", "SPEED_10_TO_15_MPS": "0", "SPEED_15_TO_20_MPS": "0", "SPEED_20_TO_25_MPS": "0", "SPEED_25_TO_30_MPS": "0", "SPEED_30_TO_35_MPS": "0", "SPEED_35_TO_40_MPS": "0", "SPEED_40_TO_45_MPS": "0", "SPEED_45_TO_50_MPS": "0", "SPEED_50_OR_ABOVE_MPS": "0", "CURVE_RADIUS_UNKNOWN": "0", "CURVE_RADIUS_0_TO_100_M": "0", "CURVE_RADIUS_100_TO_250_M": "0", "CURVE_RADIUS_250_TO_500_M": "0", "CURVE_RADIUS_500_TO_1000_M": "0", "CURVE_RADIUS_1000_TO_2000_M": "0", "CURVE_RADIUS_2000_TO_5000_M": "0", "CURVE_RADIUS_5000_TO_10000_M": "0", "CURVE_RADIUS_10000_TO_100000_M": "0", "CURVE_RADIUS_100000_OR_ABOVE_M": "0", "CIPV_NOT_ASSOCIATED": "0", "CIPV_ASSOCIATED": "0", "BRAKING_1_TO_MINUS_1_M_S_SQ": "0", "BRAKING_MINUS_1_TO_MINUS_2_M_S_SQ": "0", "BRAKING_MINUS_2_TO_MINUS_4_M_S_SQ": "0", "BRAKING_MINUS_4_TO_MINUS_6_M_S_SQ": "0", "BRAKING_MINUS_6_TO_MINUS_8_M_S_SQ": "0", "BRAKING_MINUS_8_M_S_SQ_AND_BELOW": "0" }, "stalk": { "total": "1", "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "1", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0", "SPEED_UNKNOWN": "0", "SPEED_NEGATIVE_MPS": "0", "SPEED_0_TO_5_MPS": "0", "SPEED_5_TO_10_MPS": "0", "SPEED_10_TO_15_MPS": "0", "SPEED_15_TO_20_MPS": "1", "SPEED_20_TO_25_MPS": "0", "SPEED_25_TO_30_MPS": "0", "SPEED_30_TO_35_MPS": "0", "SPEED_35_TO_40_MPS": "0", "SPEED_40_TO_45_MPS": "0", "SPEED_45_TO_50_MPS": "0", "SPEED_50_OR_ABOVE_MPS": "0", "CURVE_RADIUS_UNKNOWN": "0", "CURVE_RADIUS_0_TO_100_M": "0", "CURVE_RADIUS_100_TO_250_M": "0", "CURVE_RADIUS_250_TO_500_M": "0", "CURVE_RADIUS_500_TO_1000_M": "0", "CURVE_RADIUS_1000_TO_2000_M": "1", "CURVE_RADIUS_2000_TO_5000_M": "0", "CURVE_RADIUS_5000_TO_10000_M": "0", "CURVE_RADIUS_10000_TO_100000_M": "0", "CURVE_RADIUS_100000_OR_ABOVE_M": "0", "CIPV_NOT_ASSOCIATED": "1", "CIPV_ASSOCIATED": "0" } }, "system_interventions": { "EPAS_EAC_DENIED": "0", "COMPONENT_MIA": "0", "CRUISE_FAULT": "0", "CID_SWITCH_DISABLED": "0", "DRIVING_OFF_NAV": "0", "HEALTH_MONITOR": "0", "VEHICLE_SPEED_ABOVE_MAX": "0", "FOLLOWER_OUTPUT_INVALID": "0", "PLANNER_OUTPUT_INVALID": "0", "EPAS_ERROR_CODE": "0", "CAMERA_FAILSAFES": "0", "ACC_CANCEL": "0", "SIDE_COLLISION_IMMINENT": "0", "TRAILER_MODE_ACTIVATION": "0", "CAMERA_WATCHDOG": "0", "CAMERA_MSG_MIA": "0", "ME_MAIN_STATE": "0", "APP_ME_STATE": "0" }, "ap_unavailability": { "NONE": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "1", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "10", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "400.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "EPAS_EAC_DENIED": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "1", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "COMPONENT_MIA": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "COMPONENT_NOT_READY": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "1", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "32", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "599.500000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "CRUISE_FAULT": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "VEHICLE_NOT_IN_DRIVE": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "11" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "VEHICLE_SPEED_ABOVE_MAX": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "STEERING_LIMITS_EXCEEDED": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "CAMERA_FAILSAFES": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "TRAILER_MODE_ACTIVE": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "CAM_WATCHDOG": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "HK_TW_RESTRICTED": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "CAM_MSG_MIA": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "EAC_REQUEST_TIMEOUT": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "USER_STRIKEOUT": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "ME_MAIN_STATE_NOT_VISION": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "CONTROL_OUTSIDE_LIMITS": { "time_s": { "ROAD_CLASS_UNKNOWN": "1", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "9", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "23" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "CONTROL_PATH_UNHEALTHY": { "time_s": { "ROAD_CLASS_UNKNOWN": "1", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "4" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "CONTROL_SOLVER_UNHEALTHY": { "time_s": { "ROAD_CLASS_UNKNOWN": "1", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "2", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "2" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "SPEED_LIMIT_EXCEEDED": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "NOT_ON_HIGHWAY": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "VEHICLE_SPEED_ABOVE_MAX_HYST": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } }, "ROAD_ESTIMATOR_NOT_ALLOWED": { "time_s": { "ROAD_CLASS_UNKNOWN": "3", "ROAD_CLASS_1": "2", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "118", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "58" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "600.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "900.500000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "99.500000" } }, "UNKOWN": { "time_s": { "ROAD_CLASS_UNKNOWN": "0", "ROAD_CLASS_1": "0", "ROAD_CLASS_2": "0", "ROAD_CLASS_3": "0", "ROAD_CLASS_4": "0", "ROAD_CLASS_5": "0", "ROAD_CLASS_6": "0" }, "odometry_m": { "ROAD_CLASS_UNKNOWN": "0.000000", "ROAD_CLASS_1": "0.000000", "ROAD_CLASS_2": "0.000000", "ROAD_CLASS_3": "0.000000", "ROAD_CLASS_4": "0.000000", "ROAD_CLASS_5": "0.000000", "ROAD_CLASS_6": "0.000000" } } }, "config": { "version": "1.2", "lc_enable": "true", "autopilot_car": "true", "radar_type": "bosch", "timezone": "Japan\/Tokyo", "ISO_country_code": "392" }, "trip_log": "\/telemetry\/trip_log.pb" } }
that's been there for the last few releasesInteresting. So it's now keeping track of what kinds of roads AP and TACC are used and available on, and what speeds it is being used at.
who knows.Isn't "trip_log": "\/telemetry\/trip_log.pb" a TensorFlow protocol buffer database file?
@jimmy_d Could this be for "shadow mode", or used in some sort of driving simulation back at home base?
Why do these things always come in crazy file formats. Why dont they just make them in Paint, Word, Excel or Windows Media Player. So annoying.who knows.
Here's a sample if anybody wants to dissect it (from the above snapshot).
