dgatwood
Again, they are thinking ahead. Current H2 prices aren't relevant when they are planning for the future.
Hydrogen isn't relevant when planning for the future. Either:
- You are turning fossil fuels into hydrogen, in which case you are inherently less efficient than just burning the fossil fuels, or
- You are generating hydrogen from electricity, and it will always be less efficient than just using the electricity directly.
If we get fusion working, then and only then will it make sense to use hydrogen as fuel, because the energy obtained from fusion would be much greater than the energy spent breaking the chemical bonds between hydrogen and whatever it is attached to.
Same way, when we add BEVs to a system, it is very likely to bump up the consumption of the worst component, like coal.
If not, then that's what should be done FIRST - minimize the use of the worst component. Agreed?
No. Actually, it's quite easy to imagine a situation in which doing so makes emissions worse. Suppose you reduce coal and natural gas during the day to zero by adding huge amounts of solar power, and then you start dipping into nuclear power production (which is at that point the dirtiest power source). What happens at night? Well, the nuclear base load can't be quickly curtailed, so now you are producing less clean nuclear power, and every bit of the energy that makes up the difference at night is coming from dirtier sources than the nuclear power that the solar power displaced.
Let's take the example of Indian grid that I was checking recently due to the Delhi pollution and increasing coal usage until recently.
Indian coal plants are at 51.5% utilization. indian coal is also inferior. so they burn 0.7 kg of coal/KWh, which is 0.7 kg * 2.2 lbs/kg * 44/12 (CO2/C) = 5.64 lbs of CO2/KWh. When there are electric cars, these will crank up their utilization by burning more coal to meet extra demand.
Assuming that the current energy mix won't change over time is really not a valid assumption, but let's go with that.
Let's say India replaces 1 million ICE cars like Camry, running at 26 mpg and annual miles of 12k miles.
With this move, India will reduce (by takign them off the road)
12000 miles /26 mpg * 19 lbs/gallon * 1 mil = 8.769 M tonnes of CO2 <= Plain vanilla ICE CO2
Then, the 1M replacement BEVs @ 333 Wh/mile will need:
12000 * 0.333 KWh * 1 mil = 4000 kWh * 5.64 lbs CO2/KWh * 1 mil
= 22.560 M tonnes of CO2! <- BEV CO2 - Net addition of 13.7 M tonnes of CO2
If we replaced the same 1 million cars with hybrid Camrys, then @ 52 mpg these will add back only half of original CO2
A net reduction of 4.384 M tonnes of CO2.
Cool story, bro, but all of your numbers for EVs are badly wrong.
First, India's coal-fired power plants are estimated to produce only about 2 pounds of CO2 per kWh, on average. While that's still twice as dirty as U.S. coal plants, it's barely a third of your estimate.
Second, 4000 * 5.64 * 1 million = 10.23M metric tons, not 22.56M. So that number was off by another factor of two.
So now let's do the same math with real numbers instead of made-up numbers.
12000 * 0.333 KWh * 1 mil = 4000 kWh * 2 lbs CO2/KWh * 1 million cars = 3.628 million metric tons.
That's a reduction of 5.14 million metric tons, which is considerably more than the reduction from using hybrids. And many, many people have done that math and concluded that even with coal, EVs are typically cleaner than hybrids. Usually when your math runs contrary to a mountain of evidence, it probably means you got something wrong.
