I know this forum often talks about FSD hardware and we routinely debate LIDAR or no LIDAR, whether Tesla's FSD hardware is enough, what we like or don't like about another company's FSD hardware. So I thought it might be interesting to play a little game: If you were in charge of designing a FSD vehicle, what sensors/hardware would you pick? And to avoid the obvious answer "I would put everything on the car", you have to take into account costs and power consumption and try to keep your hardware as low as possible.
- A separate camera three inches from each of the two side cameras.
- Additional cameras at both ends of the front and rear bumpers.
That's it. The current sensor suite is basically good enough, and those small tweaks would greatly improve robustness in bad weather and when navigating T-intersections and nose-in/tail-in parking places.
Radio equipment needed to support V2I and V2V to allow the car to be more aware of the surrounding traffic infrastructure and other similarly equipped vehicles.
Definitely not. V2I and V2V are, from a computer security perspective, recipes for disaster. For V2I, all it takes is one person stealing a beacon and modifying it to send false data, and suddenly you're seeing a 90 MPH speed limit around a tight corner. Securing that sort of hardware, if broadly deployed, rapidly becomes infeasible. And for V2V, you don't even have to steal a beacon; every driver owns one.
It is fundamentally impossible to design a V2I or V2V system that can't be weaponized unless the only data it sends is limited to data that the vehicle could do without, and which the vehicle knows how to ignore if that data turns out to be fake. And if both of those are true, then what's the point of sending the data at all?
At best, if the data isn't time-sensitive (e.g. pothole reporting), it might make sense to upload it via cellular, and after being confirmed by enough distinct vehicles (with server-based fraud detection), it could then be distributed to any vehicle traveling that route. But that doesn't require V2V.
V2I would allow traffic junction optimisation and green waving meaning fewer stops at junctions and longer platoons of cars making it through the junction without stopping.
Until the first time the system gets hacked and deliberately sends two vehicles into each other. And then it will be banned worldwide, and you will have spent all that money putting in the infrastructure, only to never use it again. We can already do this with cameras, just a little bit more slowly, and without the added risk of having to trust that every vehicle is reporting its location accurately (which absolutely cannot be guaranteed, because GPS accuracy can be affected by environmental conditions, such as reflections off of walls/buildings, other cars, etc.).
V2V would allow better road utilisation in the vicinity of other V2V cars, including high speed platoons in high density lanes and better merging.
No, it really can't. Either you can see the car in front of you and know when it is braking or you can't. If you can, then you don't need the V2V data. If you can't, then you can't trust the V2V data.
The difference in density you can achieve between a raft of cars controlled by computers with multiple cameras running at 60 fps (let's call it ~20 millisecond response time) and a similar grouping involving V2V radio data (likely single-digit millisecond response time) is only a difference of a few inches of extra space per vehicle.
Except that in practice, you can't even don that. After all, radio transmissions aren't perfect. If a radio burst gets garbled by outside noise and never reaches the car behind you, if that car is counting on receiving that notification, you're screwed. By contrast, you can verify that you have a signal from your cameras, so you can rely on that for determining that the car in front of you has slowed down. You can also verify that you have a signal from your RADAR hardware, so you can also trust that to tell you that the car in front of you has slowed down. Both of these make the V2V redundant unless you're following so closely that those aren't adequate, and if that is the case, you're just asking for trouble.
Really, V2V and V2I are solutions in search of a problem.
