Interesting. I charge my car at 80A all the time, and the car has never gone into active cooling mode (running the AC compressor). It will almost always, at any charge rate, run the battery coolant pump to keep the module temperatures balanced, cool the chargers, and occasionally cut on a radiator fan to either bring them up or down towards ambient and to keep the charger cool. The chargers themselves are on the same cooling loop as the battery, and they need cooling at any temperature (on the bench, with 120V/5A charging the charger goes into thermal shutdown within about 30 minutes if I'm not actively circulating coolant through it). Most of the pack heating actually comes from waste heat from the charger. It uses the pack itself as a big heat sink. A full charge from near 0% to 90% at 80A barely raises the pack temp at all. Keep in mind that 240V/80A charging is less than 1/4C rate of charge after conversion losses. Seems like a lot, but it might as well be a trickle charge for these cells.
