I have heard that if you run your battery all the way down until it is dead, not 0% but below that until there is no more juice, then it can be recharged but the separate 12 volt battery will have to be replaced. True or false?
That is a very unusual question, but a good one. The answer is basically true.I have heard that if you run your battery all the way down until it is dead, not 0% but below that until there is no more juice, then it can be recharged but the separate 12 volt battery will have to be replaced. True or false?
Wow that sucks, I left my car unplugged for 10 days at the airport and only lost 3% charge.This happened to my 8 week old Model Y yesterday.
I went on holiday and left my car parked. I don't have off-street parking so could not leave it plugged in and I wasn't aware of this issue (naively thought that a 2022 high end car could handle a 2 week holiday). When I charged the car up yesterday I got error messages that the 12V battery needed replacing.
Fine print in user manual explains that this is not covered by warranty so I'm liable for all charges.
Tesla's suggestion to me as a customer without off-street parking was that I pay to put someone else on the insurance (necessary in the UK) and ask them to drive and charge my car while I'm on holiday.
1. that doesn't sound like the way we will increase EV adoption and get the net zero transition to happen, and 2. it's a car, not a cat.
Beyond that, it’s kind of like having a goldfish bowl right next to a 500 L aquarium, connected by a hose and the computer lets the goldfish die from lack of water because it can’t figure out how to use the hose.Wow that sucks, I left my car unplugged for 10 days at the airport and only lost 3% charge.
Agreed it's not a cat and shouldn't need fed daily
I was under the impression that the problem @D-Vox experienced was with the 12V battery, not the high voltage battery. Either way, even if s/he left sentry mode or cabin overheat protection on they should shut itself off once the HV battery state of charge drops low enough.I am going to guess that you also left either sentry mode, cabin overheat protection, or both on. If you didnt, you parked with the car at a very low state of charge before you left.
There is no other way that your car would "drain to zero" after 14 days. I can point to a few threads here where model 3 / Y owners have left the car for "weeks" / "months", and only lost 10-15% charge, like this one:
Friend opening car with no cellphone or wifi covarage
I'm away on a trip and I have my car parked in a garage with no cellphone or wifi coverage during my trip (car is not plugged in). My trip got prolonged and I'm worried that the battery will run out. I asked a friend to charge up the car. I granted the friend access to the car as a new driver...teslamotorsclub.com
Let's say he parked the car with 21%. Sentry and COP should have turned off at 20%. Still should be enough to last in the HV battery for two weeks. Must be the 12v battery that died. Probably not related to state of charge of the HV battery.I was under the impression that the problem @D-Vox experienced was with the 12V battery, not the high voltage battery. Either way, even if s/he left sentry mode or cabin overheat protection on they should shut itself off once the HV battery state of charge drops low enough.
@D-Vox : can you confirm - were both batteries dead or just the 12V battery? Did you have any auxiliary services active?
I don't do that and 35k miles and 16 months I'm on my 3rd 12v battery. They just suck
While you don't say what the state of charge was when you left the car or when you returned (if the 12v battery was dead, then you can't tell the high voltage battery state of charge when you returned), here are a couple of things I experienced:I went on holiday and left my car parked. I don't have off-street parking so could not leave it plugged in and I wasn't aware of this issue (naively thought that a 2022 high end car could handle a 2 week holiday)
Another way to reduce energy is to turn off autopilot (summon?) standby or whatever it is called.I am going to guess that you also left either sentry mode, cabin overheat protection, or both on. If you didnt, you parked with the car at a very low state of charge before you left.
