Buckminster
My MY engaged emergency automated braking today at ~5mph. Wasn't strictly necessary. Felt like hitting a brick wall. Impressive.
Why do you say it was AEB?My MY engaged emergency automated braking today at ~5mph. Wasn't strictly necessary. Felt like hitting a brick wall. Impressive.
Said so on the screen. I wasn't on the brake.Why do you say it was AEB?
Did you save the video clip by chance?Said so on the screen. I wasn't on the brake.
In the context of reducing Model 3 cost 3k-7k by going from stamped to cast, the areas that can be changed:Easy - many MANY fewer employees on each line. We know, Elon has stated, that the lines for the Y are much shorter than for the 3 (this is why unlike the S/X line they cannot be combined).
When you are space constrained at Fremont as well, reclaiming some of that space by shortening the line, that's gold.
EDIT - and throughput, number of cars per hour, is higher off those lines that use casts than those using welded parts. Fewer stations, time per station lower.
EDIT2 - and the number of "reworks" of cars with a problem exiting production is lower. Fit and finish is higher. Win Win.
Simple, don't throw away the old robots from the old body live that are no longer needed. Ship them to another new line/factory instead of buying new bots. Yes there will be new costs for the new stuff to support giga castings, but that improves margins in many ways going forward as already pointed out by others, plus you get to reduce costs elsewhere with the reused bots. It shouldn't take long to measurably improve things, at the rate they're going.
One of the many many things an expanding company, like Tesla, has going for it (re-use partially obsoleted technology elsewhere) that a stable or declining company can't (GM, Ford, etc.)
(if at all since you still carry the old equipment cost unless it gets reused).
Yeah, I can totally see it for a new line, it was conversion of an existing depreciated setup that I had trouble swallowing. Similar to Elon's comments, it's inefficient, but it works.My source is from a friend in Tesla management. I will honor his request to remain nameless, but this is a person that has been on-stage with Elon.
It's fact, if they transitioned the Model 3 over to a cast setup, there would be substantial savings in both space, manpower, and $$$.
Also, bear in mind, for Fremont, half or more of the Model 3 robots are all fully depreciated, as that line has been churning out cars since late 2017 (5 year point - which is often the depreciation schedule for equipment like this).
EDIT - Elon himself even said with an interview with Sandy Munroe he would love to transition the Model 3 over to a cast setup for cost savings and improved throughput, but it wasn't practical because of the downtime involved when they have so many orders to fulfill.
I thought it was 2 GA and one body line?If memory serves, Tesla has 2 lines for the Model 3 in Fremont.
I think this is the issue.I would be possible to take one down at time and completely retrofit for casting usage (although, they would need to find room for casting machines - Fremont is a trainwreck in terms of layout and available space).
Could something like Stable Diffusion run on our Teslas as an app?
It 'could', but would it work well?Yes.
As to efficiently/ natively:It's Linux Ubuntu, so anything that'll run (or can be ported to) that. But will Tesla allow it? 3rd Party code is fraught with unknown+longterm risks.
Yeah... but the question was "run on", not "display the results from"... i.e. web browser.This is a technical question, but it doesn't have to "run" on the app, the request to run is sent by the app, it is run in the cloud and the rendered image is sent to the app. So doesn't have to be a native or ported function, but rather a cloud function.
At least the refresh Model S&X have a discrete GPU for gaming that would probably provide decent computing power...As to efficiently/ natively:
Tesla FSD chip TRIP is based around 8x8 int multiplies with a 32 bit accumulator. Stable Diffusion uses float32 (or float16 for memory limited systems) weights.
Reminds me of running Autocad on a 486SX25 with math co-processor emulation.
Oh yeah, there are lots of CPUs and GPUs running around. TRIP could probably do it too by breaking up the math like on an standard 8 bit processor.At least the refresh Model S&X have a discrete GPU for gaming that would probably provide decent computing power...
Does no one downshift any more?I have driven from the highest drivable point on MT Rainier back to south of Seattle WA without having to use the brake’s. That’s going from 6,500 feet to sea level in 80 miles. I’d do much better going down long grades without the car trying to get away from you and having to ride the brakes.
