I've started thinking about applying the high amount of regen braking in the Semi to track racing.
Specifically if a Tesla Roadster and/or Plaid+ Model S could have a peak regen rate of 300-500 kW. Not only does this save the brake pads, it captures a lot of energy on the track, extending range.
My impression was the Roadster was originally 2 x 100 kW 18650 packs - 200 kWh.
Getting something close to that might be possible by making 4680 cells a bit taller say 46 x 120....
If a Roadster (perhaps with front and rear castings) has (for example) a (structural) 46120 pack with 160kWh-180 kWh and say 350 kW of regen, it may be able to slay any ICE vehicle on a track including over longer durations.
A larger pack size is needed to maximise regen, the Plaid powertrain does the rest.
For track racing even Supercharger V4 probably doesn't charge fast enough to complete. The best bet is avoiding the need to charge. perhaps eventually followed by battery swapping.
The only place battery swaps might make sense is track racing.
IMO the high purchase price for the vehicles will partially offset the additional R&D costs, this also allows Model S and perhaps Model X to move to 4680 cells and for higher numbers to be built if that is desirable,.
Obviously this is a lower priority than Gen3 vehicles, but the Roadster will provide a strong clue..
