Yggdrasill
You have one phase 400V plug? That's unusual, and not something a Tesla can use to charge. (Edit: Actually, it should work if you have neutal available, then you basically have two phases. Though the car would interpret it as a fault with the third phase and be unhappy.)A factor two, to be exact.
Incidentally, that is also a possible uncertainty factor involved when only stating the charging capacity in ampere, since the other factor, the voltage, could be 110V, or twice as high, for twice the charging power.
The charging power is really what one needs to know.
For example, my garage has only a 16A outlet, but with a 400V voltage, so I have a charging power of 6.4 kW. A night's charging (say 12 hours) will thus give me a good 76 kWh. Now I just need the car itself...
I would think you have a three phase plug, with a total power of 11 kW. Or 110 kWh in 10 hours.
