Is glass roof noisy?
Discussion in 'Model 3' started by insaneoctane, Aug 23, 2017.
Tags:
  1. insaneoctane
    insaneoctane Active Member
    Southern California
    Sorry for the simple question, but I notice in my current car a significant difference in noise when I close the moonroof fabric cover in the cabin. Even though the moonroof is closed, if I open the slider panel, I can hear noticeable wind noise, particularly at speed. I am curious if there is more noise through the glass roof? Any S/X owners have experience with this?
  2. gregincal
    gregincal Active Member
    Santa Cruz, CA
    I would think that there is a big difference between an openable moon roof versus a fixed glass roof in terms of noise.
  3. Pinot.Noir
    Pinot.Noir Member
    Livermore, CA
    I have the fixed glass roof and there is no noise from it at all.
    • Helpful x 4
    • Informative x 2
  4. CTreast
    CTreast Member
    Georgia
    This question has been on my mind too. My wife has a pano roof on her Ford Edge and we recently had to replace the front windshield. It must not have been shaped like the one from the showroom because it introduced a lot of noise that we never noticed before. I'm OCD and all I can think is thank god it's not my car. Which puts me to wondering about the model 3.
  5. jelloslug
    jelloslug Active Member
    Greenville, SC
    My roof in my Model S has never said a word.
    • Funny x 8
  6. JonathanD
    JonathanD Member
    OC, CA
    It's nothing compared to the AC compressor!
    • Funny x 3
  7. Neo_fd3s
    Neo_fd3s Member
    Aurora, Ont
    You can't compare an opening moonroof to one that is fixed. Obviously the moonroof that is capable of opening will always have some air creeping into places since it's capable of being opened. Which is why you notice more sound insulation when you move the cover back in place.
    The fixed glass is just that, a fixed piece of glass. It's taking place of an entire sheet of metal. Meaning it has to be sealed exactly like its steel counterpart.
    Differences are weight, and the ability to see through it as opposed to the steel one. Otherwise there shouldn't be any sort of air creeping in. If there is, it hasn't been installed properly.
    Can't wait to fiddle with the online configurator for my region. Yes, I know alot of the details will remain the same, but there's always subtle differences depending on your country. And yes, I"ll be getting the fixed glass roof. :)
  8. Ken7
    Ken7 Member
    New York
    And although I'm getting the fixed roof too, I do worry about the transmission of heat on a sunny day. Without a sunshade, it does concern me.
  9. chronopc
    chronopc Member
    I'm more worried about the amount of heat and glare coming in than the sound.
  10. BluestarE3
    BluestarE3 Active Member
    Norcal
    Model 3 Glass Roof Sunshade
  11. Ken7
    Ken7 Member
    New York
    Yup, I'm aware of that, thanks, but it only covers the front area and I'm also concerned about the aesthetics of it as opposed to a factory installed sunshade.
  12. Trips
    Trips "Boring bonehead questions are not cool. Next?"
    Omaha, NE
    I expect road noise to be more noticeable as it is will all EV's. If I remember right a lot of people added sound proofing if various places to reduce this on the early Model S. The process is fairly easy if road noise does turn out to be an issue.
  13. chronopc
    chronopc Member
    Is $75 expensive for a sunshade?
  14. Thomas Edison
    Thomas Edison Member
    Portland-ish
    I believe it's 1/2 the price of the model S version.
  15. Ken7
    Ken7 Member
    New York
    Not sure if it is since I've never had to buy a sunshade, but my concern is not the cost, but rather the aesthetics and the fact that it only covers the front half of the car and not the other half.
  16. chronopc
    chronopc Member
    I hope the tinting is really dark.
  17. DR61
    DR61 Member
    Redding, CA
    Given the number of 3's expected to be delivered, I would guess that there will be aftermarket sunshade solutions for both the front and rear passenger positions.
  18. JasJ
    JasJ Supporting Member
    Houston, TX
    I have the all glass Model S in Houston and it's dark enough that I forget I have glass overhead. Minimal heat intrusion unless it has sat in the sun all day - then if you use pre-cooling, it's still a non-issue.
    As for noise, more comes from the side doors/windows and not the top of the car and then only at 65 mph and above.
    I suspect the M3 will be the same.
  19. chronopc
    chronopc Member
  20. JasJ
    Houston, TX
