Great post, @lolachamp.
@richkae, you've asked the $64,000 question: what is the
future of the grid? Let me start by trying to answer a related but different question, why does the grid look the way it does?
First, what does the grid look like? At a high level, the transmission system was built to move large amounts of power from concentrated sources -- large power plants or systems of dams -- to load. The grid is cross-linked, so that the loss of one element (a big power plant or major transmission line) doesn't interrupt service. High-voltage lines form the backbone/skeleton of the grid, with a series of lower voltage lines stepping down to finally deliver power to each customer. The operation of the grid is run from a handful of centralized control rooms, where the generation at each facility is carefully monitored and controlled to assure reliable service and the ability to recover from a disruption.
Why does it look this way? Economies of scale (at least, historically):
- Large thermal power plants burn fuel more efficiently
- Large power plants produce more power / employee
- High-quality hydro resources are concentrated, often far from load.
- High-voltage lines have lower line losses and lower capital cost (per MVA)
- Regulatory hurdles make it harder to build many small generators (100 MW) rather than one big one (800 MW)
- Controlling the grid requires lots of information and expertise
Many of those factors are crumbling, though not all. In particular, distributed resources are becoming cheaper, particularly when you add in the costs of bolstering the grid. Also, telecoms and IT have improved so much that a lot of the control room operations can be built into the grid's hardware.
Microgrids are clearly The Next Big Thing, inasmuch as they have much better economics in some areas. The challenge is how to maintain continuous service on the microgrid. If you install backup fossil-fueled generators, those are still far less efficient than grid-scale generators. If you buy off the grid, then there's a difficult negotiation about the cost of that standby service.
As @lolachamp suggests, no utility has seriously stepped up to the plate on reimagining the grid and its role. This is a MUCH bigger step than deregulation in the 1990s/2000s, which merely shuffled who owned and operated assets, without fundamentally changing anything about the grid. Edison and Westinghouse would immediately recognize nearly everything about the U.S. grid, while Bell wouldn't understand today's telecoms infrastructure.
My simple take on the Koch Bros. actions is that they are being classic conservatives, in the literal sense. They make excellent money selling oil, gas, and coal under the century-old utility model. Of course they want to slow or stop any change.
