This has been written several times now, and you seem to ignore this vital piece of info. Tesla DID NOT use the term motor power in Denmark.You're kidding with this, right? You aren't owed any compensation because there was absolutely NO false pretense. Tesla is required by law in the EU to advertise motor power, and that is exactly what they did. For what do you want to compensated by Tesla, the fact that it correctly advertised the motor power as required by EU regulations? Go and sue your government.
Tesla should just let them give the car back and they will give them their money back minus depreciation, of course. They can then buy a different car.This has been written several times now, and you seem to ignore this vital piece of info. Tesla DID NOT use the term motor power in Denmark.
That could be a fair option.Tesla should just give the car back and they will give them their money back minus depreciation. They can then buy a different car.
Customers (at least this one) would much prefer the company to develop and maintain the highest integrity standards. This includes (promptly) admitting and correcting mistakes, and addressing the consequences of those mistakes. Cutting corners isn't going to work in the long run.
Any link to the eu rules that show it is ok to spec total motor power, if the battery or fuel pump and injectors on a ICE car cant deliver enouh to make that power.
Where? I have read the ECE 85 document and cant find any info about it beeing the europe rule to be ok to only list the max power of the engine without considering fuel or battery power the car can provide.I've posted about it up the thread:
Letter To Elon Musk Regarding P85D Horsepower – Discussion Thread - Page 37
- - - Updated - - -
What exactly does this mean? Didn't Tesla used their website in Denmark? Do you mean that version of the website they use in Denmark was/is different from the websites in other countries? If so, can you provide a link or a snapshot of how their website looked in Denmark?
Thanks
https://www.google.no/url?sa=t&sour...fRuCOc&usg=AFQjCNERBajjXvEFCkQJ6QmHZisgbKWwQg
Note: If the battery limits the maximum 30 minutes power, the maximum 30 minutes power of an electric vehicle can be less than the maximum 30 minutes power of the drive train of the vehicle according to this test.
Danish website was indeed different yes. Screenshot shown several times in the "Calling all owners"-thread started by the danes. It in other threads as well. Thats why I am getting tired of people not respecting the danish claims here. They have clear undebatable proof that Tesla advertised the car as having 700hp.I've posted about it up the thread:
- - - Updated - - -
Thanks
The ECE R85 regulation includes specific rules on what power rating of the electric drivetrain should be and specifics on how these ratings have to be confirmed via designated tests. The ratings that manufacturers are directed to use for electric drivetrains are NET POWER (Max Net Power) and MAXIMUM 30 MINUTE POWER covered in paragraphs 5.3.1 and 5.3.2.
5.3.1.3. Just before beginning the test, the motor shall be run on the bench for three minutes delivering a power equal to 80 % of the maximum power at the speed recommended by the manufacturer.
5.3.1.4. Measurements shall be taken at a sufficient number of motor speeds to define correctly the power curve between zero and the highest motor speed recommended by the manufacturer. The whole test shall be completed within five minutes.
That 400kW would be split over two motors.One key part of the test though is this
I think there is no argument that a Model S motor is pretty limited under the 30 minute rating. (69kW across the board). What we don't know is how long it takes before it gets too hot. 1 minute? 2 minutes? 29 minutes?
Can a Model S motor run for 3 minutes at a constant 400kW ?
[/FONT][/COLOR]
[/FONT][/COLOR]
As for your 69kW rating, it is exactly the same as the "Maximum continuous rated power" on the EU certificate of conformity (CoC) for the P85 (from 2013). I suspect whatever sheet you had just had an incorrect number.
The number is supposed to be filled in on the V55 by looking at the certificate of conformity. Since the 2013 P85 CoC didn't have a maximum net power number, only a "Maximum continuous rated power" number, I suspect that is what they used to fill in that line.
http://assets.dft.gov.uk/dvla/V355_290613.pdf
The V5C that you were issued would then reflect the numbers of whoever filled in that application (but it may not match up with the CoC exactly).
The newer EU certificates for the P85D give three different power ratings, where the "27.3 maximum net power" corresponds to the motor power Tesla advertises.
If you look at a V5C of a P85D, I suspect it will have the correct numbers there.
http://www.teslamotorsclub.com/show...tions/page28?p=1166701&viewfull=1#post1166701
As I've mentioned in our discussion before, the 69kW is not the 30 minutes power, it is continuous rating of the motor. It can run at 69kW indefinitely.
I can assure mine is not an isolated case they all say this (I've seen 4 personally, and spoken to numerous other people in UK / Norway / EU), so it isn't some simple clerical error on the part of someone filling in a form.
The figure given for the 85D is actually lower on official documents @ 67kW.
We are going round in circles here, but I find it highly unlikely a Model S motor can run at 400kW for 3 minutes straight. Why would Tesla design it to do so? It is pointless in the real world, and the only reason would be to pass an EU test that up until now no one gave a hoot about.
- - - Updated - - -
Yes and can it run 400kW for 3 minutes?
If not the test is invalid for maximum.
I didn't say it was an isolated incident, just that whoever decided to fill in the V55s for Tesla decided to fill in the continuous number rather than the actual maximum net power numbers. One possible explanation is that the CoCs previously only had the continuous number (as it appears to be the case from my search) and they continued using the same number even when the newer CoCs have three power ratings listed.I can assure mine is not an isolated case they all say this (I've seen 4 personally, and spoken to numerous other people in UK / Norway / EU), so it isn't some simple clerical error on the part of someone filling in a form.
- Item. 27 ("Maximum continuous rated power) : 69KW. Very low value since the motor is capable of 320KW. Maybe this is good in view of future tax measures EU government will inevitably take to draw money from Tesla owners... ;-)
From P85D certificate of conformity:
27.2 Maximum hourly output: 66kW
27.3 Maximum net power: 193kW (front), 350kW (rear)
27.4 Maximum 30min power: 79kW (front), 90kW (rear)
I don't think so
Is this misleading advertising an accident? An oversight? Or is Tesla trying "to pull a Volkswagen"?
Is there any technical reason they can give combined hp for the 70D and 85D but not for the P85D?
I would humbly suggest that we don't conflate this issue with the Volkwagen crimes. Even stipulating that Tesla was intentionally misleading (I peraonally think they were just careless, but can be swayed), they are orders of magnitude apart in severity, intention, and consequences.
The consequences for Tesla are yet to be determined.
