Since there are two bulbs required, you should gain 16 W (10W - 2W)*2 = 16 W. This means you get 2 miles per 37.5 hours of driving!
Or at $0.14/KW hour for electricity, you'll save $8.75 for every 1000 hours your lights are on.
These are the kinds of big savings I live for! Use 1W bulbs and save even more (although not much more).
Two bulbs? Where. Once over the rear plate and...
The link provided by Araxara indicates these are 1W bulbs in the heading. However, reading the specs in the ad states they are 2W each. Has anyone received these bulbs yet to confirm their actual wattage, and whether the brightness is correct? Thanks.
My car is still being serviced - it won't be back till 18-Jan, so I can't compare the brightness on the car. I have nothing, other than my eyes, to compare brightness, but I'll set up an external comparison running the original incandescent bulbs and the 1W LEDs in parallel. Also, due to the color difference of the bulbs, the LEDs will appear brighter for the same light output. As I stated previously, turning the LEDs away from the lens will reduce the brightness a bit - the housing is not very reflective.So, are the LED lamps as bright as the original bulb, or brighter? You indicated that the first LED bulb you installed were too bright. Are these new LED bulbs you selected comparable in brightness to the ones supplied by Tesla?
Those "bulbs" are actually a circuit board with a single LED soldered on, they are not conventional replaceable bulbs. I'm sure someone could glue on and solder a few more LEDs (and proper current limiting resistor), but it would be a hack job. Also, it's unclear if additional heat sinking would be required.Can brighter LED bulbs be ordered for the Frunk and Trunk spaces that would fit directly in the current lighting fixtures? I know there have been post of adding lights to the area, but it would be great if we could just upgrade the bulbs for an incremental improvement.
On a related front. Can brighter LED bulbs be ordered for the Frunk and Trunk spaces that would fit directly in the current lighting fixtures? I know there have been post of adding lights to the area, but it would be great if we could just upgrade the bulbs for an incremental improvement.
I wonder why Tesla went old-school with these bulbs.
Notwithstanding the energy savings noted above, I find that LEDs in that position look substantially better at night that incandescents (IMHO). They really do stand out from the crowd in traffic.
How's the color temperature of these bulbs? I tend to dislike the cold, bluish tint from cheaper LEDs. I'd prefer a more neutral white to match with the rest of the lighting on the car.
Possibly a DOT requirement, that the bulbs be easily replaceable?
The bulb color appears about in the range of 5000-6000K. They are pretty white - slightly bluer than daylight. On the car they appear no more blue than other LED license plate lights.How's the color temperature of these bulbs? I tend to dislike the cold, bluish tint from cheaper LEDs. I'd prefer a more neutral white to match with the rest of the lighting on the car.
I am assuming that if you are replacing an incandescent/halogen/old school bulb, then it does not matter if you get regular or error free since regular bulbs don't have a circuit board, and therefore, the car is not looking for data from the bulb if it came with regular bulbs OEM. I would then follow through to assume that the Model S with OEM old school license plate bulbs does not care if the LED replacements are error free cambus or plain Jane LED, and that only newer cars that had LEDs as OEM are a potential concern for error messages with the wrong LED bulb selection.
There are error free LED bulbs and regular old LED bulbs.
I'm guessing most white LEDs in the Tesla are in the range of 3000-3500K. These have been slightly brighter than the lower color temperature 2700K color for the same cost. When you buy consumer 120 VAC LEDs or CFLs they sometimes indicate warm or cool or daylight. This roughly translates to 2700-3000K (warm), 3500-4000 (cool), and 4500-5000 (daylight), but there is no official values for these labels. Likely more than you wanted to know!
Yes, that's right for individual LEDs, although some manufacturers, such as CREE, have LED modules which have a color rendition index (CRI) greater than 90.IIRC, LEDs don't have one "temperature", but isolated spikes that emulate white. Artists won't use them for that reason. (Gaps in the palette.)
