I assume that you made an error when you stated you have a “250 amp plug”. That is not possible in a residence. Did you mean 240 volts and 50 amp?I have 250 amp plug and I am using Tesla charger but I am setting only 7 mph. I used to get 30-35 mph last week but it now dropped to only 7 mph?? What can I do ??
Check the easiest thing first... Make sure your charge current on the charging screen didn't get reset to a lower number.
are you talking watts?I have 250 amp plug and I am using Tesla charger but I am setting only 7 mph. I used to get 30-35 mph last week but it now dropped to only 7 mph?? What can I do ??
WHAT?are you talking watts?
when you switch the battery range indicator from Miles to Percentage on the display, the Charging Rate also changes from Miles to KwH charging rate. 30 Miles per hour charging rate is roughly equivalent to a 6-7 KwH charging rate.... Those are the figures I see at my home charger. So maybe he is confusing those numbers not realizing the change in metrics. Given those two figures match up almost exactly, I believe my inference to be a reasonable one?.... but thanks for the ALL CAPS response!WHAT?
Besides saying "kW" twice for your units, I think you figured this out. I have seen this exact thing on this forum from a few new owners. They see just the number by itself and somehow completely miss that the units after it have changed. And it has gone from a 30-ish miles per hour charging rate to a 7 kiloWatts charging rate, which are actually the same thing, but in different formats.when you switch the battery range indicator from Miles to Percentage on the display, the Charging Rate also changes from Miles to KwH charging rate. 30 Miles per hour charging rate is roughly equivalent to a 6-7 KwH charging rate.... Those are the figures I see at my home charger. So maybe he is confusing those numbers not realizing the change in metrics. Given those two figures match up almost exactly, I believe my inference to be a reasonable one?.... but thanks for the ALL CAPS response!
How do you switch the indicator from miles to kw?
