Hmm so 1.5” in the front and 1 7/16” in the rear.
And that’s before any settling.. it seems Eibach May be expecting a 1.2” drop on the v1 suspension (pre Jan 2018).
If you stiffen up the car you get into slippery territory. Was it excessive, repeated unabsorbed shocks that caused that window to fail?Anything aftermarket can void the warranty for that specific part if it was deemed the culprit of the breakdown. So if your window or door handles stop working, no the lowering springs won’t void that.
Installed the Eibach springs this morning, job took about 4.5-5hrs including prep and cleanup. Was done with suspension in about 4hrs.
View attachment 321235 View attachment 321236 View attachment 321237
It looks perfect for me. Did you take any pics/video when swapped the springs? What did you use for Spring compression?
Looks great!Installed the Eibach springs this morning, job took about 4.5-5hrs including prep and cleanup. Was done with suspension in about 4hrs.
So Eibach quoting it to be a 4hr job was pretty accurate which included alignment too, so not too bad. Still gotta take the car in to get an alignment to make sure the toe is good so I don't cause any early wear on the tires.
The front went from 29 1/8in to 27 5/8in.
The back went from 28 1/2in to 27 1/16in.
The gap in the front is about one and a half finger and the back is just about 1 finger. So even with the Eibach springs the rear is just a bit lower than the front. As in the closeup pics to show how much of a gap is left, the wheels are 19x8.8/19x9.5 (F/R) VMR V801 (Anthracite Metalic) and the tires are 245/40-19 275/35-19.
No way I'm waiting for air suspension. I test drove air suspension and did not like it at all.Will the upcoming air suspension on the lowest setting be a good alternative to lowering the car with springs? I'm considering holding off on ordering till next year for air suspension.
There are a couple of threads on TMC about this. At this time all we have to compare to is Model S. As I recall, the settings on the S are HIGH (+ .75"), STANDARD (+0"), LOW (- .75"). and SUPER LOW (- 1.5"). The big advantage is that you can set the SAS with either manually or automatic GPS for specific locations, like my driveway ramp, from the U.I.Will the upcoming air suspension on the lowest setting be a good alternative to lowering the car with springs? I'm considering holding off on ordering till next year for air suspension.
Thanks. I didn't realize there was a Super Low setting?? From my research all I've seen is a Low setting which was -0.79".There are a couple of threads on TMC about this. At this time all we have to compare to is Model S. As I recall, the settings on the S are HIGH (+ .75"), STANDARD (+0"), LOW (- .75"). and SUPER LOW (- 1.5"). The big advantage is that you can set the SAS with either manually or automatic GPS for specific locations, like my driveway ramp, from the U.I.
Very nice! Do you have a body kit on yours? And how is the ride compared to stock?Eibach springs installed. Im on WedsSport SA-20R Ride quality is ok at best...having 20"s on low profile doesnt help. Im satisfied with the height drop. the 4-5 finger gap before lower springs, really bothered me. View attachment 321617 View attachment 321618 View attachment 321619
My Model Ss have had very high, high, standard and low. Standard is a bit lower than the coils that were offered at the time I got the car.Thanks. I didn't realize there was a Super Low setting?? From my research all I've seen is a Low setting which was -0.79".
Thank you, I was not remembering quite right. Here is a screen shot of the MS U.I. with SAS:My Model Ss have had very high, high, standard and low. Standard is a bit lower than the coils that were offered at the time I got the car.
SAS will lower and also raise the suspension height. That is one of the main selling points for SAS is to improve clearance for driveways, etc. Yes, it will lower (if you chose to) at highway speeds to improve aerodynamic efficiencies.
This is the exact wording from the website:
"Experience superior handling, efficiency, and ride comfort. Adjust the height of your Model S. Smart Air Suspension also utilizes the GPS of your car to recognize the location of past adjustments to suspension height and automatically updates when you revisit specific locations, such as a steep driveway."
And here is the actual in-car setting page:
Found the spec on Tesla support page: Model S Specifications and also on the web site toward the bottom: Model S | Tesla
So the "Very High" setting appears to only give less than an inch with a single RWD motor. I also think the low point of the undercarriage is somewhere farther under the car. I also wonder if the spec accounts for Tesla adding undercarriage protection for the battery case?
- Clearance 5.3"(Dual Motor)*, 5.5"(RWD)*
With air suspension 4.6" - 6.3"
Looks great!
Got a pic further back like on the road? How is the ride over stock springs?
I installed some Eibach pro lowering springs on a EK Honda, loved the handling.
I agree on the great look...and congrats on doing it yourself and saving some cash! I have to say I'm a bit surprised with the measured drop closer to the UP springs 1.5". I'm scheduled for noon today at Eibach's HQ in Corona so I might be the first "factory" install to report in. They told me the same people who developed the M3 springs will be doing the install so I'll question the discrepancy. After some test driving and speed bump work to settle the springs they will do the alignment the same day. Is this too soon?
My car (with the 245/40-19 rubber all around) still measured close to yours with the front a bit lower at 28 7/8" and the rear a hair under 28 1/2". I'll report the new measurements by tomorrow morning. I can live with the lower look but I sure hope it doesn't settle and more than 1.5". The TSportline springs seemed to settle in closer to 1.2" rather than the claimed 1.0". Do the UP springs settle more as well? They do look lower to me. Its amazing how even a fraction of an inch can be so obvious to the eye.
Update: Sorry, no pics to share but the drop after my Eibach springs install is surprisingly less than I expected at 1.1" in front and 1.0" in the rear. Measured after only 40 miles of driving so I expect those numbers might increase a bit. I think it looks great...1.5" of gap in the front wheel well and 1.25" in the rear. If it settles a bit more I won't complain. Ride does seem a tad firmer but not unpleasant at all. Fresh pics in the morning.My car (with the 245/40-19 rubber all around) still measured close to yours with the front a bit lower at 28 7/8" and the rear a hair under 28 1/2".
