Daskid
714 tires in Westminster did my lr rwd alignment
How much do they charge? Did they have the alignment spec for the Model 3?
Is that a p3d?
Glad I went with the T Sportline springs....just enough of a drop for me without the rear sag.
Is that a p3d?
You mean adjusted?Can the coil over be cut? I am discussing with a friend about it.
Looks good. 1" drop front and back?No its not a p3...its a long range dual motor...but I have OEM perf brakes up front but rear OEM perf brakes wouldn't work so I had to put stock ones back on but did get them painted.
Thank you for posting this! I have been looking for an example with AWD and T Sportline as I just bought them and plan to install this weekend. It looks FANTASTIC! Best I have seen, yet!
Cutting the OEM coil spring
Nice ride @mact3333 !
How come the rear factory p3d brakes didn’t work ?
And what size and width are your wheels/ tires?
How come you went the route of AWD + paying for p3d brakes instead of just getting the p3d right away ?
The car is dropped 1 inch front and rears...the tires are 245/35/20 and 275/30/20...wheels are 20 x 8.5 and 20 x 10.0...weights are supposedly 24 and 25 lbs.
Long story but I bought the awd long range cause I got a good deal on a inventory car and I had a deposit on model Y performance...so I was only going to keep this car for 2 years and getting ultimately the model Y...but I like this car so much(much more than I thought I would) I decided to just keep this one hence the upgrades...tbh, I dont regret it cause if I bought the performance model I'd prob get new wheels and tires and springs so I'd be out another 5K anyway...while 0-60 3.2 s would be nice, my car seems plenty fast to me and Ive had some fast cars in the past.
As far as rear perf brakes, my installer talked to lead Tesla mobile repair guy and both showed concern that it wouldn't work due to ebrake not working and throwing codes(so software issue also)...I didnt quite understand it all myself...but installer didnt want to try it.
I am going to research this more cause I still have the perf rears sitting in garage and want to make it work since they were expensive.
I see.
Any software issues with the front brake change over ?
Are you doing this for aesthetics?Nope, the fronts went on without any issues so this can be done. Weird thing is this, I haven't found a single member on here that has swapped out the rears for perf. brakes...I find that odd...this also means that you couldn't upgrade rears with Brembo's or Stoptech or any other after market BBK's also.
I am sure a work around will be found one day.
Interesting. Never knew there was another manufacturer of springs for the Model 3.
