Exactly, so you would want your cells to be kept cool when drawing 20 Amps from them, right?
Now, how do you get to the point of lowest IR to maximize power, i.e. the Max Battery Power function... :wink:
This is the reason I have yet to decide to have the upgrade done or not.
In the next couple of weeks I'm going to do some more measurements with my CAN bus logger to see what happens at 17A (Insane mode).
jpet, I don't know what ambient temperatures you see throughout the year, but to me, I'd expect Ludicrous' biggest benefit is the dis-proportionally greater HP gain witnessed at lower SOC, and cooler temperatures. I don't know, for sure, but it sounds like working the 30-90mph range harder in public, seconds at a time, is simply not a problem. Your access to faster European roads is unique. As it is, I get "
1+ hour" to "Max Battery Power" whenever it is even 35-40F degrees. So many owners are in CA, where sub-40F (<5C) really doesn't happen much. Then, so many upgraders, so far, are CA only. I think there's more feedback to come, from owners freshly backing their cold
P85Ds out of the garage, in more typical U.S. environs.
Last weekend, I saw my first blue snowflake (left of the dash battery bar) and had the battery down to ~10%. It's obvious cold/SOC is a bigger issue to performance, than heat is to batteries. A relative statement, I know.
