AlanSubie4Life
Efficiency Obsessed Member
It would hardly be the first time Elon tweeted something that turned out to be.... at most polite...exceedingly exaggerated.
That's a supply issue though since they had a 3rd party making the spoilers and badges and weren't getting them in sufficient quantity/quality for a long time, so after-delivery install was the only option.
They really wouldn't though- since they could always just use extra P-spec PN motors for AWD cars if there's a surplus.
Which, allegedly, they already do anyway right?
But it also means having a different PN makes it simple to handle replacement parts in the future without needing a secondary, secret, provides-0-benefit system for doing so.
...why?
Instead they just slap on the PN for P motors on those that passed P testing, and the PN for AWD/RWD motors on those that do not.
Doing anything by serial is more work, harder to deal with, and doesn't help in any way.
Now sub "part number" for serial # and that remains true, without adding a second, totally pointless, level of abstraction.
Serial # can be useful info if, say, you realize you had a defective setting on your assembly line between dates X and Y, or a bad batch of capacitors or something between some dates, to figure out which parts might have a problem later.
it's a crap way to do supply chain/repair/replacement part tracking though. Worse in every way and for no benefit.
(by all means if there IS some benefit you can't already get just using PNs for this stuff- let me know- but we've been debating this for a long time now and nobody's come up with any)
Yeah, we'll probably won't know for sure for quite some time, if ever. In any case, it's pretty likely that at least some (maybe even all) AWD cars have motors that are capable of P-level performance.
* Anecdotally, my P motor appears to be from the bottom of the P bin, as power is pulled (unless I'm in track mode) at 92% SoC. So it may be less efficient than some P motors. As I said earlier, maybe it's an AWD motor! (Hopefully it's just a software issue, one of these days I'll check again.)
