In any case, as an economist I always evaluate activity at the margin, not on average. If I work another hour, will I earn enough extra money to offset the lost enjoyment of the hour elsewhere? If I eat another doughnut, will that make me happier (or just fatter)? If I charge my EV at midnight tonight, how much more carbon will be emitted? This marginal thinking leads to right action in nearly all circumstances.
I completely agree. However, the same goes for every load, because any load has the power to reduce CO2 emissions at the marginal rate by disconnecting. That's why the blame must be shared by all who continue to use electricity, and not just the latest added load or class of load.
I'm not arguing against the concept of marginality, I'm arguing that you can't use it to assign the blame, i.e. the highest CO2 emissions rate, to the newest type of electric device. All electricity consumers must continually evaluate whether their consumption is acceptable, because reducing it will reduce CO2 emissions at the marginal rate. But if you want to calculate the CO2 emissions of one type of electricity consumer, then you have to use the grid average emissions rate, because all other consumers are just as guilty of not removing their load. Said another way, dividing the consumers into high or low emissions groups based on when they appeared is meaningless as only the next change, positive or negative, will make a difference.
About carbon tax: Is the following correct? A carbon tax would make low-carbon sources preferable to the utility, and to the extent that carbon must be used it will increase the price of electricity. That would force some of the least useful load out. This fits in nicely with my idea that all consumers must share the blame (and consequently the grid average CO2 rate is correct for calculation of EV emissions): All consumers end up paying the carbon tax equally according to their usage, in the form of increased electricity price. If the return on the expense is too low, they will cut their consumption. The price is set on the margin, but affects all consumption equally (disregarding the lag due to long term contracts, but new long term contracts will be based on the new spot price).
