The partition used for snapshots is only 10G so it's not like it can store 38G either.On .44 and just got back from a 3000 mile trip and my X has pushed about 38GB to the mothership... I can’t imagine it had much more to upload given its storage limitations...
Hmm...should I be concerned with eMMC flash wear? 38GB just sitting in the garage is insanity
I've seen those posts too and that's why, in hopes to ease off on the eMMC writes, I enabled energy savings settings and unchecked "always connected" to allow the car to sleep as much as possible to extend eMMC lifespan. I've read that if car is not sleeping - it's logging something - writing and re-writing to flash memory.There’s a few posts about premature eMMC wear cause CID failure from possibly all the read/writes but also the temp of the CID, but nothing statistical yet I don’t believe.
I figured, I can wait 30 sec for car to wake up if it saves me $3-4k bill in a few years.
I'm just going from what I've read:Sorry, but no those syslogs are "always" running unless your power off the car in the CID, I believe.
The CID doesn't sleep even with energy saving mode.
Actually I am not 100% sure of that. It's true when you have "always connected" checked, but if not it might be sleeping.
CID consists of few separate processing units. Main computer which is responsible for graphics and many other things callled Tegra. This computer definitely sleeps. Everybody who has CID on a bench knows that. Gateway subunit is not sleeping. It is responsible for waking everything up if signal comes in. This unit has two flash storages and logs communication lines (can & eth) extensively. Log files stored on SD card that could be removed and replaced. We didn't hear about wearing and failing SD yet though. So far we've seen multiple cases of failing Tegra, particularly eMMC flash memory on it. It is main data storage for Tegra, soldered to the PCB.
I confirm what @verygreen says -"always connected" setting is evil since it makes Tegra to be always awake which increases vampire drain and much more increased wear of flash memory, accelerates failure. If you have classic MS - beware of using this setting.
At the cost of a lost MCU out of warranty, I'd take the extra 10 seconds to "wake" if it was me (well it is, and thats what I do haha)
How relevant is this to the recently built models? I'm assuming the potential for issues is the same, is that right?
Still relevant, it will fail one day... when has yet to be seen. Think of it like a cell phone, or a video card in your computer.
They should provide the option to remotely log to our own syslog servers.
Bruce.
no they are not.They're already at the point where, from a security standpoint, having access to the Ubuntu systems does not alone compromise the vehicle.
What do you guys use to monitor wifi traffic for your car upload and download? I need to change my infrastructure. I want this data.
no they are not.
