Massive data uploads since 2017.34 2448cfc
Discussion in 'Model S' started by dakine1, Sep 2, 2017.
Tags:
  1. dakine1
    dakine1 Member
    phoenix, az
    • Informative x 9
  2. Patrick W
    Patrick W Active Member
    SLC, UT
    What app are you using to get those data?
  3. Jays200
    Jays200 Member
    Perth, Western Australia
    Ya need to charge your phone ;)
    • Funny x 7
  4. vrykolas
    vrykolas Member
    The Colony, TX
    It's Google wifi (app & device) which allows easy/automatic teaching of data usage per device in real-time or over a period of time
  5. conman
    conman Member
    Melbourne, Australia
    #5 conman, Sep 5, 2017
    They've started logging much more information in a recent firmware (maybe yours?) to add to the neural net for EAP +/- FSD. This is possibly related. Do you drive much with autosteer enabled?
  6. Xenius
    Xenius Member
    Havertown, PA
    +1 for google wifi. I really need to see if I can isolate the tesla on mine to see this kind of data.
  7. Cirrus MS100D
    Cirrus MS100D Member
    Pennsylvania, USA
    I don't have a pretty chart like that, but my home WiFi (TP-Link) does show a similar pattern:
    8-21-17: >5MB
    8-22-17: >10MB
    9-3-17: 7MB down / 358MB up
    9-3-17: 6MB down / 100MB up
    9-4-17: >5MB
    Interestingly, the only driving done on 9-3 was a round-trip to/from home to EWR airport (about 130 miles total.) A majority of the drive to/from was done using Autopilot on Route 195 and 95/NJ Turnpike.
  8. MarcusMaximus
    MarcusMaximus Member
    San Jose
    It's not terribly hard to do. It'll show up as an unidentified device(just an IP address), where most other things on the network show up as named in some way. So turn off as many wifi devices as possible, connect the car to wifi and see what shows up. Then you can edit the name to whatever you want.
    On the general thread: I went back and looked at my stats and, sure enough, massively increased uploads. Looks like Karpathy is doing his job.
  9. DaddyP713
    DaddyP713 Member
    Georgia, USA
    Holy crap, that's impressive! 3.3 GB...mine averages a few hundred MB, but I'm a few releases back...
  10. outdoors
    outdoors Supporting Member
    Deep inside a bunker charging away.
    Similar here. You can see when I got the car back in July. Then big bump in late August.
  11. Hugh Mannity
    Hugh Mannity Mediocre Member
    Port Haney, BC
    Isn't the general concensus that these are maps? I wonder how large the kernel update would be?
    • Disagree x 1
  12. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    It could just be a bug in the data uploading software.
  13. brkaus
    brkaus Active Member
    Looks like it's data the car is sending to Tesla (or somewhere). Not data the car is downloading.
  14. thecloud
    thecloud As rhythm raced inside, the ship came alive
    Sunnyvale, CA
    "Uploading" means the car is sending data to Tesla, not receiving data from Tesla.
  15. Hugh Mannity
    Port Haney, BC
    Oh oops right you are, nevermind ;)
  16. chillaban
    chillaban Active Member
    Bay Area
    One theory I'll propose:
    Take a look at the TeslaFi breakdown for AP2: Around 20% are still on some form of 2017.28, 45% on 2017.32.x, and 13% on 2017.34. And the rollout of 2017.28 -> newer has basically stopped for AP2 (the most 2017.34 reports are from people with 2017.32.x or who had a SvC appointment).
    Given that 2017.34 has increased the telemetry parameters for snapshots, I strongly suspect they have placed multiple control strategies in the field and they are trying to gather data on which works the best, before they upgrade everybody to a newer version.
  17. verygreen
    verygreen Curious member
    TN
    There are also another more mundane explanations.
    Every time an autopilot process crashes, a crashdump is uploaded to Tesla.
    The random snapshots are controlled independently of software version so should not depend on a particular version.
    It's possible they started to collect more data that is car/firmware originated of course (e.g. they used to collect FCW snapshots and then stopped), I guess I'll try to verify this once I get my hands on this release.
    • Informative x 3
  18. chillaban
    Bay Area
    Curious….. That makes me wonder instead if this new build is just crashier than previous ones and that's why it's generating more traffic.
    BTW, with root, are you able to control what firmware gets installed on your car? I recall one of the previous tinkerers saying that he found a way to do so but won't say any more than that for fear of it going away….
  19. verygreen
    TN
    Even without root as long as you have the actual firmware file you can ask the car to install it. Now getting that firmware file somehow is a totally different matter.
    • Informative x 2
  20. verygreen
    TN
    #20 verygreen, Sep 7, 2017
    So.... I got this release installed and did a short two minute trip and...
    Code:
    2017-09-07_13:40:08.xxx-0700 Trigger core dump snapshot
    2017-09-07_13:40:08.xxx-0700 I0100 00:00:00.000000  2935 snapshot_task.cpp:264] RAW: OneShotRequest available in queue
    2017-09-07_13:40:08.xxx-0700 I0100 00:00:00.000000  2935 snapshot_task.cpp:771] RAW: Calculated xxx free bytes on disk
    ] RAW: Uploading archive: anonymize = 0
    2017-09-07_13:40:08.xxx-0700 I0100 00:00:00.000000  2935 snapshot_task.cpp:639] RAW: Wrote /home/telemetry/snapshots/snapshot-119ce422-f5b0-4f15-8e9e-c46cc2440823-0000.tgz, requester: core-dump
    in fact I have a whole bunch of them as it turns out. All from Vision task, about 2M each. I'll try a longer drive soon to see the accumulation rate, I guess.
    • Informative x 5
