I mean yes you could pay for their day rate, $300 or something
Can anyone provide the following for me?
As a contribution, I uploaded a cheat sheet that someone else may find helpful. Unfortunately I can't upload an editable one just a PDF.
I have the MPP sport coilovers with the adjustable camber and toe arms.
I have tried a few things and seem to make things worse. Ex. no shims on front =-2.8 but then I got understeer.
Example of what I am looking for and can't find.
Front Driver Front Passenger
Camber -2.8 -2.8
Toe -.05 -.05
Rebound -6 from hard -6 from hard
Compression -6 from hard -6 from hard
Input requested
Camber
Toe
Rebound
Compression
Rear Driver Rear Passenger
Camber
Toe
Compression
Rebound
Or just rent a garage for $250/day, for 30amp outlet. In-car SC map actually shows a gray out SC in Laguna Seca. Hopefully, it will be red in the near future
Hey, why so pessimistic.They don't charge fast enough to be worth while. It's also heavy. I do have a Honda I could use, but they would do nothing more than 5-8% in between session. It's more for top off than anything else.
Here are my alinement settings at 110mm ground to battery. It’s very difficult to get more than -2.8 camber on the front.
The car will understeer more than oversteer so you may want to purchase UP sway bars and go full soft front and full stiff rear. I can get my car to rotate nicely.
Also attached are MPP recommended suspension settings depending on if you’re at a low grip/technical or high speed/high compression track. Typically for autocross I use 7/6 all the way around. 7 being compression and 6 rebound.
Thank you.
Yeah, I think I will need the UP sway bars. The -2.8 front camber gave me (I think) more body roll and definitely understeer (had to point people by)
I hadn't see the updated MPP specs.
I am surprised to see you have a square camber setup, I was thinking of 1/2 as much in the back.
I see you have front toe out (makes sense) and rear toe in. Have you tried toe out in the rear or not as much as .2 toe in?
I went through a set of front tires in less than 7,000 miles with a more aggressive alinement, so this new setup is a good compromise between daily driver and track. Plus at this ride height I couldn’t get anymore rear camber. I set the rear toe in slightly because the rear was floating a bit at high speed.
I’m very happy with this setup. Over the weekend I had the fastest raw time in a regional autocross event. The car was ballistic! Competed in Street Modified and it was over two seconds faster than any other vehicle in SM and half a second faster than all 150 vehicles which competed that day. In the end the Raw time was good for 17th in Pax.
Awesome, can't argue with success!
May I ask what wheels and tires with sizes and air pressures?
What's your wheel size and offset?Hoosier A7’s 285/30/18 29psi cold
You just need to add DC charger to it and for ~20K you can tow your own 250kw supercharger. Now you also can consider renting a place on a track to keep it, so just come with a lot of diesel fuel next time. Or organize people who go to the same track and buy megawatt generator. Then slowly propose track management to either buy it from you and sell kwh to everybody or lease some proper DC charger and invest in cables...
Hi,
I own the 2020 M3P. I plan to take my car to the track frequently next couple of months. I was checking with the local auto service companies like Midas, Firestone e.t.c to get the brake fluid flush done and replace it with Racing brake fluid. None of these guys can source performance brake fluids so can't do this service for my Tesla. I checked a local performance car service who never done it for a Tesla before but said he could do it If I brought the 3 quarts brake fluids myself and quoted $290 for the labor?
Does this sound right?
