Just a little thought to keep in mind: Slow charging (particularly 120 volt, 12/16 amp) is less efficient than charging at faster rates because the fixed portions of charging overhead remain active longer.
When I charge using the Mobile Connector at 120V/15A, I get 85% charging efficiency. When I charge using the Wall Connector at 240V/48A, I get 97% efficiency. I drive my Model Y about 45 miles per day and spend about $50 per month for 240V/48A charging at 12¢/kWh. Even though 120V/15A charging is fast enough for me, I would be wasting about $6 per month due to the losses associated with slower charging. Granted, that's not much, but I'll sure accept $6 per month from anyone who is willing to give it to me!
The moral of this story is: For the greatest efficiency, charge as fast as you can at home.
$425 Wall Connector
($250) less rebate
$175 net cost
$230 Mobile Connector
$50 Bryant 9450FR receptacle
$180 Square D QO 50A GFCI breaker
$460 total cost
Note that I did not include the cost of wire, conduit, or labor since I did the installation myself and they were near my panel, so the cost was minimal. Even if I already had a receptacle for the Mobile Connector, the cost would be similar after the rebate.
Also note that I have both setups for a few reasons:
In my case, the net cost for a Wall Connector was far less than the cost of a Mobile Connector because my electric company gave me a $250 rebate for installing a WC.I think I’ve read Gen 2 have an advantage for power sharing?
A new TWC at $475 saves needing a 14-50R and GFI breaker, and seems price competive, I only have 1 but it said it could share “in the future”
$425 Wall Connector
($250) less rebate
$175 net cost
$460 total cost
- There are no fast chargers in my area, so home charging is critical.
- If my Wall Connector fails, I need a backup charging method until I can replace it.
- A Mobile Connector gives me a backup charging method for home and allows me to charge at work if my power is out at home, for example.
