I just don't know how else they would reach 250 mph, while delivering 0-60 times of 1.9 seconds without adding at least one more gear. The two specs are pretty incompatible without changing gearing at least once.
Not incompatible
Low speed acceleration is based on torque which is based on current limit
High end speed is limited by:
- Max motor RPM
- Motor Back EMF
- Pack Voltage
- Force needed
To hold a speed, the car needs to put out as much power as there is drag+friction+drivetrain loss.
The output power is (Pack voltage - BackEMF)/MotorReistance * PackVoltage (for 100% duty, add in your own motor factor for accuracy).
Factoring in max motor RPM, if the gearing needs to double for the 250 MPH number, then that divides the motor to road torque by 2 and the backEMF vs road speed by half.
With a 200kWh pack, the pack can likely do at least 2x the current of the present top dog top dog. This then goes to twice as many rear motors. Each motor only has half the available load (one loaded tire vs two). So each motor can only put out half the power/ torque of the 100DL before wheel spin kicks in. With the modified gearing, that puts the motor right back where it started. So, each motor produces the same shaft torque at the same current level as a P100DL yielding the same total rear wheel torque.
At the high end, there is double the power available due to dual motors. By reducing frontal cross section and coefficient of drag, that gets most of the way to the needed 4x power for 2x speed increase. Plus there is the gain of PM vs AC induction motor.
They could also use a higher voltage pack to increase top end (less likely due to part reuse)
Last knob to turn is trading torque per Amp (low end) for V/RPM (high end) by using a different motor winding.
