Model 3 Electric Motor
As I understand it the Model 3 will employ the front motor found in the D versions of the Model S. Does anybody know how much power potential this motor actually has? I remember reading that the front motor is a lot more efficient than the older rear motor, and I strongly suspect (if from nothing more than a gut feeling) that Tesla is sandbagging the thing at 259hp. Even at that level though, a dual motor setup in the Model 3 will still be 518hp. However, it would be nice to see them turn up the wick on the motor(s), if there's more power to be made.
In '18 S and X will already have different motors and controlers, why would E get the current motor?
Tesla will continue to improve the motors in various important aspects. They design and make the motors, why stop the design?
I don't recall having said it would receive an older version of the front motor found in the MSD. From what I've read in various threads in this forum, the motor should go through at least one more iteration before the 3 is released.
shokunin
P85 & M3
1,214
653
Irvine, CA
I don't think the motor is the issue. Even with the P85D and P90DL, power is limited by how much energy the battery can supply the motors. The Model 3 won't have as many cells as the MS (due to size) so the maximum energy delivered using current 18650 cells/chemistry would be less. But a smaller and lighter car could get away with less power.
We'll have to see what happens with the gigafactory and what new chemistry/cells they will produce with higher energy draw or capacity. After 3 years, we've moved from 85KW to 90KW, I was hoping we'd be at 100KW by now..
GSP
2,614
877
Elon or JB has said the Model III will have a new design motor. It will incorporate learnings from the original Model S, and the D motors. Compared to the latest D motors, I would expect lower cost, longer life, more reliability, and maybe a tad more range.
GSP
I desperately hope that Model 3 is mostly aluminum. I want Model 3 to be a "different" car from others. Aluminum construction is just one more thing to differentiate it from normal cars.
With the Ford F-150 going aluminum, I don't know how "special" it is anymore. Kind of like LED headlights. Heck, they come on a Toyota Corolla now. I really don't care if it's made out of bamboo, as long as it delivers the desired attributes. My guess is the roof, hood and liftback might be aluminum, but the primary structure and body will probably be steel.
