Thanks for catching the typo.That should be 52.1 kWh for 220.
That makes the pack size including a 4% buffer ~54KWh.
Since I have been estimating 1C charge rates, I like your data better ;-)Allowing for the bottom buffer (I suspect that's the right way to figure this, as the 0-100% range excludes the buffer), that's 55% of 73.5KWh or 40.4KWh of energy. That's an average rate of 81KW for the first half hour, or a roughly a 1.08C rate.
Can you think of a reason why the larger pack would have a lesser C rate ?
One other point: Should't the C rate be based on nominal capacity rather than usable ?
Certainly not gospel. Good enough for spit-balling, however.I think we should also be careful of over analyzing possible website oversights or typos and simplifications or roundings by marketing people......
The result you might be seeing is that MPGe is a worthless measureStarting from 126 MPGe for the EPA combined cycle for the 310 mile Model S,
this works out to a 82 kWh usable capacity pack.
Seems too high a result. Am I doing something wrong here ?
That I know; it just forces me to calculate backwards for a Wh/mile result I can actually use.The result you might be seeing is that MPGe is a worthless measure
Yes, you're not subtracting the charging losses. EPA MPGe data is wall-to-wheel. The EPA range data is battery-to-wheel.Starting from 126 MPGe for the EPA combined cycle for the 310 mile Model 3,
I disagree.All MPGe does is confuse the average person into thinking that EVs are actually hybrids that use gasoline.
Miles per kWh or kWh per mile are great ones for starters.I disagree.
MPGe allows people to compare the efficiency of gas and electric cars using a measuring stick most people are familiar with.
If you can come up with a better term, by all means send the suggestion to the EPA.
I think it serves it's purpose very well.
It is useful in countries where 1kWh costs the same as 1 gallon.that MPGe is also useful.
I don't think that is right.The EPA range data is battery-to-wheel.
By Luke Ottaway Aug 19 2014 - 6:42am
How the EPA determines an electric vehicle’s range - not as simple as it sounds
The standard MCT test procedure consists of four UDDS cycles and two HWFET cycles in a specified sequence including mid-test and end-of-test constant speed “depletion phases” which vary in duration depending on the vehicle and the size of its battery pack.
At present, only the UDDS and HWFET are required for EPA certification of a battery electric vehicle – if no other cycles are run, as is typically the case, the range and efficiency values are estimated by applying a correction factor of 0.7 to the UDDS and HWFET results to estimate the effect of the three supplementary cycles mentioned above.
Additional minor corrections are then applied to the test-obtained values before the final range and efficiency numbers go on the label.
