AlanSubie4Life
Efficiency Obsessed Member
Still was hoping to hear your comments on my prior post. I would like to understand the tradeoffs here - and I might be missing something in the prior plots posted. (They make it look like there is a lot on the table below 45mph if you can use the large amount of unused battery power at those speeds to produce power at the wheels (with the “downside” (not an actual downside!) that acceleration, proportional to the slope of the power vs velocity plot, would start to decrease from a higher peak at a lower speed).)If you really want better 0-60, you need more watts from 15 MPH to 45 MPH. And that's the battery that is limiting that, even today. The motors are not the limit.
Is this motor capable of higher currents at the same voltage (so more power) at low speed? If so, from plots above, it should help with faster 0-60, shouldn’t it? There is not a battery limit until 40-45mph. Maybe I am missing something (see prior post!).Their innovative laminate and magnet structure along with carbon winding allows them to reduce the air gap between the rotor and stator. This increases torque at the same voltage. This is not free- this requires more current at the same voltage
Do you happen to know whether the carbon-sleeved rotors are more efficient?They absolutely cannot afford to mess with the efficiency millions of Model 3's just so a few of us that care can go slightly quicker.
Also, maybe the gain is marginal, but would going to a permanent-magnet motor in front help efficiency at all?
For cost efficiency of course it makes no sense to make changes but actual efficiency doesn’t seem incompatible with higher performance in this case, does it? (Though the gains are probably pretty marginal.)
But are you saying they will do nothing? I think you are not saying that. But not sure!The answer is nothing. Because the whole point is to get great 0-60 times out of a high volume commuter car.
Seems like doing nothing would result in no significant change in performance which they probably can’t afford to do. (I guess I could see them making minor tweaks to the Model 3 motor to get a bit more torque, and maybe there are other material advances which allow tighter tolerances on the rotor without carbon sleeves, would be a halfway and cheaper solution.)
