El joe
Sounds like somehow you got a RWD. The 0-60 matches the old LR RWD version, which I wish they still offered.
Would be super easy to check for half shafts behind the front wheels.Sounds like somehow you got a RWD. The 0-60 matches the old LR RWD version, which I wish they still offered.
What tires are on the car? Tires are pretty important factor
Not on this car they're not (for 0-60 or 1/4 mile times anyway, they obviously make a big difference if you're measuring stopping distance or something)- the 3 is not traction limited for acceleration.
Even the performance model 3 runs about the same times on top-end summer performance tires or mediocre all-seasons.
Alternative explanation - the LR AWD, AWD Acceleration Boost and all flavors of P are indeed slow.... just ask that tri-motor rehash of a decade old EV tagged 'Plaid' and found in other sub-sections of this and other fora.
dragy is not a 'high end' system. also, your phone is not remotely capable of being accurate. then you need to make sure your battery is warmed up.I've had my M3LR for approx 2 weeks now. I loved it initially until I started looking at the 0-60 times. The BEST I've had on a full charge is 5.3. Most times avg. 5.6 seconds. I'm sorry but I paid extra in part for the faster car. I feel like I paid for a LR but got the performance of a SR. I've used several apps and got the same times. I haven't been to track or used a higher end system like Dragy but I again, I've used multiple apps with same results. Very disappointing. Any suggestions or recommendations?
buy an adapter cable and install a bluetooth obd scanner and use scanmytesla to read the parameters. you will be able to see how much juice is being pulled by the motors under full load and know if there's an issue instantly with actual power delivery.I have done almost everything you stated. I stopped at a supercharger on the way home. Charged it to 90%. Went 1/4 mile to the entrance ramp. Came to complete stop.timer said ready-go and I did. For a whopping 5.7 seconds. I had the precondition battery note and went from 40% to 95%. None of it matters
I’d be all over it!Imagine if the king returned with a heat pump, heated steering wheel and a 83kwh battery..... one day maybe...
No special pedal technique is required, didn’t think the car would even allow it. Just gives you a both pedals depressed warning
you are 100% correct, he must have a RWD version. my brother has this config, and 5.4-5.6 0-60 is accurate, they are not fast. long range and AWD are not mutually exclusively. the bigger battery won't give you any more power, you need the OTHER motor for more power.Sounds like somehow you got a RWD. The 0-60 matches the old LR RWD version, which I wish they still offered.
