AlanSubie4Life
Efficiency Obsessed Member
Not sure what you mean by “it”. Mine is a 2018, but I believe we are talking about software issue not hardware, and I am on 2019.40.50.7 which is latest release. I think if you look at thread, the mysterious 293 has been reported by many owners, not just 2020 cars.
By "it," I mean the adjustments to the range/charging constant based on wheel selection, and the unlocking of an apparent additional 1.7kWh of energy from the battery, which as far as I can tell only applied to 2020 Performance vehicles so far.
All the people reporting with Performance in a brief perusal of the first couple pages here had 2020 3P vehicles. It was associated with the 2019.40.50.1 update (see post above with that info).
There have been other 293 rated miles @ 100% reports (I saw one), but they are likely just coincidence. To know for sure, you (or people reporting such mileage) should take that picture of the Energy Consumption screen as shown above and assess what your constant is. If it's still 245Wh/rmi, and not 265Wh/rmi, then it's just simple degradation. You'd also presumably know that the constant hadn't changed because you wouldn't have seen a huge (~17 rated mile) step change in mileage immediately with an update (see a couple examples above). If you didn't see that, then it's also likely it's just gradual loss of capacity.
That constant is key. If you have 293 miles and you're stuck at it, but your constant is 265Wh/rmi, I wouldn't worry about it - your battery is in awesome condition (you have 2% more energy available than you started with - or they re-scaled kWh) - and it would be the first report that I've actually seen for a non-2020. If you have a one-year-old car and it's showing 293 out of the original 310 with the original 245Wh/rmi constant, I also wouldn't worry about it - it's capacity loss of 5%, which appears to be well within what is normal for that vehicle age/mileage.
Based on what I've seen, it would be quite unusual to have vehicle that's a year old that HASN'T seen any loss of available kWh.
FYI, I have a 2018 3P+ with 300 rated miles @ 100% (3% degradation). I saw no changes with 2019.40.50.x.
Also, as mentioned earlier, my guess is that this is just the first step in the rollout towards 299/304/322 for the Performance, and 322 for the AWD. They just have not yet rolled to AWD at all, and I suspect there will be further constant adjustments to get to the EPA numbers, even for the Performance (~260Wh/rmi20, ~256Wh/rmi19, ~241Wh/rmi18 would be my guesses).
I think they're probably being careful because they did (apparently) unlock additional capacity (which I'm sure they think is ok since they did the EPA compliant test with it in their Fremont lab presumably), but they just want to be sure. Based on the EPA documents (datafiles, calculating the recharge event energy) it actually looks like more like just 0.5kWh extra energy available, so maybe it is a combination of kWh reporting adjustments and battery capacity unlock. But the recharge event energy small change (0.5kWh vs. my hypothesis of 1.7kKWh above) could be smaller even with a larger 1.7kWh unlock, due to AC-DC charger conversion efficiency improvements (which would improve efficiency but not range). Would just need to be 1% more efficient...
