Knightshade
Sorry my post wasn't very clear, as you missed every point I tried to make. I'll try once more and then take my own advice.
My point is that you can lot sort just the motors (a single part), then combine them with the rest of the drive unit and you will have, in some sense, a "lot sorted drive unit."
No, I got that point.
It just doesn't change the result.
At that point you're still sorting the same part. The motor going in each unit is still the same part, just sorted. So it also would not support the idea the motors are any different between models.
You're stuck on one interpretation of Elon's tweet (which may very well be correct), but it's also possible he just shortened it instead of spelling out exactly which part of the drive unit was lot sorted.
Motor is fewer characters than drive unit... so that suggestion also doesn't hold up to examination.
if he used the longer name it's probably because it's what he actually meant.
I mean- literally every fact we have to go on supports the notion the drive units are exactly the same between P and non-P cars other than being lot sorted. Every single piece.
There's not a single piece of actual evidence even suggesting otherwise.
Not to mention how much easier/simpler it makes things from a manufacturing speed/simplicity perspective.
This is reminding me of the "I'm sure it must have a HUD" thing at this point. Folks just "want to believe" something for which all the evidence says otherwise so they're gonna insist we "don't know" even though they're unable to support their argument with anything other than that.
