Yes most people believe all versions of the model 3 have the exact same rear drive unit. Only differences come from software limitations.
There are two drive units. What about the front unit vs the AWD?
Too bad it's behind a paywall...
Only works if you've not exhausted your "free views" for the month.Google the title of the article...
What if my spoiler isn’t installed, dual motor badge removed and calipers painted black.
Will I be treated as a spy?
I don't see why you'd test and bin motors+inverter together
Elon Musk on twitter said:Performance drive units are lot sorted for highest sigma output & get double the burn-in
I
, when you could have higher yield by binning them independently, then taking the product. It's not like manufacturing an inverter has *ANYTHING* to do with manufacturing the motor. Different materials, different process, different equipment.
A) Makes people feel better about paying 11k for what is essentially a software unlock
According to your interpretation.You'd have to ask Elon Musk, since he's the one that told us that's how they're doing it.
Your way would require double the amount of testing and lot sorting, and then sort integration between them to insure only a "best" goes with a "best", which would likely add complexity to the process and slow down manufacturing.
A
Your way would require dismantling a drive unit for remanufacture when they shove a non-working inverter in it and the test fails.
I know it's like trying to make the ocean more salty by peeing into it but
Could people not discuss whether something is 'software unlocked' has ANY bearing or value whatsoever towards the cost of something?
Even if its literally flipping one bit from 0->1 there is so many layers of costing and R&D across the product lifecycle develop and operations that make so and so cost so and so.
I was just there today and can confirm that they do not have a performance model 3, only a RWD version. They expect to get their performance model in a couple of weeks.The rep who did my Model S test drive and told me it was a performance model was the stores "fleet manager" (or something similar to that) so I would assume he would know what he was talking about. I should have stopped and taken a closer look when we walked past. Guess I'll find out for sure on Monday.
EDIT - I emailed the rep who called me to set up the Model 3 test drive - she confirmed it is a performance model.
Weird. Her exact words from the email: “It will be the performance model. I drove it yesterday, it’s awesome!”I was just there today and can confirm that they do not have a performance model 3, only a RWD version. They expect to get their performance model in a couple of weeks.
I'm also a little confused at how even if they did bin the parts separately that would change the fact they're the same parts.
Because again, otherwise the idea of binning them makes no actual sense.
The way Elon actually said it's done:
They lot sort a batch of drive units- the same part all. The top ones go in a P, the others go in non-P cars. Both types of cars got the same part, the Ps just got ones that are (likely marginally) higher "scoring"
The way you're suggesting they do it.
Exactly the same thing, except they bin twice. It's still binning the same parts. The inverters are the same for all model 3s, just the highest scoring go in P DUs. The motors are the same (well, all rears are and all fronts are) and the highest scoring go in P DUs.
Other than more binning work, your way doesn't change the original statement that they're the same parts in all the 3s, just lot sorted.
"Same part"? It's almost like you know nothing about manufacturing... huh
Why are you talking to yourself?
Anyway- Lot sorting is when you take a bunch (or lot) of the same physical part then performance test it, and then sort them by the results. At that point you can use those sorted into different groups for different purposes.
If you start with 2 physically different parts then "lot sorting" them makes no sense. They were already "sorted" before you started.
Elon Musk explicitly stated they are doing lot sorting with the drive units and the best ones go into the P.
So they are taking the same physical parts that make up the DUs, and lot sorting them.
Not sure how you're still getting confused about this?
That’s certainly one possible interpretation. It also seems possible that the motors are tested and sorted before being installed in the drive unit and have different components based on performance or not (yes, I realize Elon said “drive unit.” It’s possible he was referring to the motor, since lot sorting part of the drive unit still results in a lot sorted drive unit). No one here has enough information to say one way the other, so arguing about it is kind of pointless.Why are you talking to yourself?
Look, you are wrong. So let’s move on.
EDIT - and this being the internet, I realize what I just wrote is wishful thinking at best...
My point is that you can lot sort just the motors (a single part), then combine them with the rest of the drive unit and you will have, in some sense, a "lot sorted drive unit." You're stuck on one interpretation of Elon's tweet (which may very well be correct), but it's also possible he just shortened it instead of spelling out exactly which part of the drive unit was lot sorted.That's not possible at all though.
If the components are different for P units it makes no sense to lot sort them.
They're already sorted by virtue of having different parts from one another.
Lot sorting only makes sense to sort a batch of the same actual parts to pick up small differences in manufacturing variance.
That's why the "they must be different parts" bit doesn't make the slightest sense.
I mean, it's possible he meant "tires" too. But since he was on twitter and used a longer term, with a specific, more complex, meaning, he probably meant the words he actually used.
But again, even if it's sorted at the motor level and then at the inverter level, and then combined later, that's only possible if the same motors are being lot sorted and the same inverters are being sorted. That's what the term means.
This was referring to my attempt to tell people on the internet to stop arguing - which is the advice I will be taking now. Hopefully we will get some more information soon.sure- though I do appreciate the irony of you presenting an argument and then telling us how pointless said argument was
Use the ignore feature. Several threads have become much easier to follow and read.Sorry my post wasn't very clear, as you missed every point I tried to make. I'll try once more and then take my own advice.
