Model S dead, "Vehicle may not restart"
Discussion in 'Model S' started by Zuikkis, Feb 23, 2021.
  1. Zuikkis
    Zuikkis Member
    Finland
    Our MS died. :(
    The car is in our garage. Wife was supposed to go to the work, but couldn't get the car going. It showed a message "Unable to start" on screen, followed by "Vehicle may not restart". The same messages are viewed on the app:
    After that, MCU went blank and indeed does not restart. I have tried reseting with the steering wheel buttons, it does not wake up.
    Car seems to have working +12V, because I can open frunk, trunk and central locking normally, and brake lights light up when I press the brake pedal.. Charging port opens from the keyfob, but the cable can't be inserted as the lock does not unlatch. So basically it seems only MCU is dead?
    Is there some MCU fuse that I could pull, to try "force reset" the MCU?
    Car is a 2013 P85+, with MCU2 retrofitted a few months ago! So it's not MCU1 emmc issue.
  2. jpvdheijn
    jpvdheijn Member
    Baarle-Nassau, NL
    Try to take of the nose cone. And put a lager 12 volt battery on the terminals and see if the screen boots. I guess tesla will need to take a look at the vehicle. Keep us updated
  3. Zuikkis
    Zuikkis Member
    Finland
    Heh, we are in sync, I guess. I just connected a battery charger to the posts, and MCU woke up immediately. It is still showing some errors and does not start, but I'll let it charge for a while and see again.
    I'm out of warranty so the next step is that I'll buy a new battery and replace it myself..
  4. Zuikkis
    Zuikkis Member
    Finland
    Any recommendations for the 12V battery?
  5. jpvdheijn
    jpvdheijn Member
    Baarle-Nassau, NL
    Last year I had a similar issue, I thought it was the 12volt battery but it did not fix the issue. In the end the car was towed to Tesla and they measure the HVIL loop and found that the battery heater was faulty. This was replaced at the SEC with a new revision part, costs were around 950 euro's.
  6. jpvdheijn
    jpvdheijn Member
    Baarle-Nassau, NL
    I would use whatever you have laying around as 12 volts. The 12volt of the model s is only there to run accessories and is being charged by the DC-DC converter taking power from the HV battery.
    But do only put that 12volt battery on the terminals behind the nosecone.
  7. Zuikkis
    Zuikkis Member
    Finland
    Ah. I have a 10Amp C-Tek charger plugged on to the terminals. It has been there for 1 hour already and there's not much progress happening on the status leds, which would indicate that the battery does not charge properly.
    So I am thinking about replacing the actual battery myself..
  8. Nikxice
    Nikxice Active Member
    Hudson, NH
    If the problem is the 12V, I'd be curious as to why you didn't get a preemptive warning, "12V Battery Needs Service"? If the car is now awake, displaying error codes, Tesla might be able to diagnose your issue remotely.
  9. Zuikkis
    Zuikkis Member
    Finland
    Yeah, good point.
    But I have seen batteries fail on other cars "just like that" without any warning, typically single cell short circuits for no reason which makes the total voltage drop by 2V. Somehow this seems to be the situation here. The battery has now been charging for 2.5h and it still only shows 12.5V with multimeter. Should be way over 14V while charging.
    Now if I try to start the car, it first says "Voltage too low", followed by the earlier "Unable to start".
  10. random155
    random155 Member
    NJ
    If you decide to have the 12v replaced, I would have Tesla do it. Im a DIY person but I've read of guys replacing their 12v and having problems that need a tech to correct. Its only about $200 well worth it to avoid headaches with more errors. Just a suggestion, I never thought I'd think about paying someone to replace my car battery. lol
    My vote is 12v battery issue
  11. Zuikkis
    Zuikkis Member
    Finland
  12. Palmtree
    Palmtree Member
    Missouri
    Please keep us posted on what you find out.
  13. Zuikkis
    Zuikkis Member
    Finland
    Car is being towed to service center at the moment. Turns out my insurance covers the towing, making this choice easier.
    I managed to fully charge the 12V battery, and also tried attaching a separate 12V battery to the nosecone terminals.. But the errors are still there, car unable to start.
    Also the fact that it refuses to unlock the charge port.. Must be some high voltage failure because it doesn't want to allow charging?
    There's also some new warnings:
  14. 46&2
    46&2 Member
    Switzerland
    Good luck with the car!
  15. Plasmid_Boy
    Plasmid_Boy Member
    Indiana
    I had a similar problem a while back on my 2014 P85+. It was caused by a dead AC compressor.
  16. krsgio
    krsgio Member
    Colorado
    I had the bms_w035 error on my car about a month ago and it ended up being battery heater but the car still continued to drive. Not sure about the other errors
  17. Jughead135
    Jughead135 Member
    Georgia
    Better get that wiper fluid checked, stat!!!!
    :p
    OK, you may not be seeing any humor in this at this point—it just struck my funny bone, all those dire-sounding warnings, with a “wiper fluid low” message.... Hope you get this sorted easier rather than harder....
  18. viper2ko
    viper2ko Active Member
    This makes me deathly afraid that my Tesla is out of warranty
  19. 2101Guy
    2101Guy Active Member
    #20 2101Guy, Feb 24, 2021
    you arent sure if you are in warranty or not?
