Perhaps but maybe not enough. The Model 3 Performance has track mode and brakes are still a complaint. (Albeit doesn’t have torque vectoring.)Yes it will make a huge difference.
The brakes are constantly being used under acceleration.
I track my performance 3 with the stock brakes and a street and track pads From unplugged.Perhaps but maybe not enough. The Model 3 Performance has track mode and brakes are still a complaint. (Albeit doesn’t have torque vectoring.)
I do not. Just going based on videos I have seen with others that do.I track my performance 3 with the stock brakes and a street and track pads From unplugged.
you track your Tesla?
It’s stock brakes are excellent. Definitely enough with track pads.I do not. Just going based on videos I have seen with others that do.
It’s (Plaid) not quite ready for the track yet. You can’t rotate it at all!! Zero! It’s definitely needs SW track pack.I do not. Just going based on videos I have seen with others that do.
No reason to disagree. The video is above this comment.I have no doubt less nanny on the traction control will do wonders.....
But, the brakes suck full (lack of) stop. Sorry to disagree so much but my right foot and butt do not lie to me. All working being done in a straight line when selective brake caliper actuation would not be involved.
Indeed (an especially interesting comment given your reaction to my post directly above )"No reason to disagree."
Is that you racing?Indeed (an especially interesting comment given your reaction to my post directly above )
and no, I do not track a 5k lb street car.
and have a bit of experience with brakes
Is that you racing?
I raced ama superbike.
I would love to say the 5000 lbs is the problem, it’s not.Indeed (an especially interesting comment given your reaction to my post directly above )
Can you elaborate "Brakes aren’t the problem, temperature is."I would love to say the 5000 lbs is the problem, it’s not.
It’s (the Plaid won’t allow any rotation at all!!!) zero. It’s almost applying full braking under acceleration out of a corner. I am sure you’re aware what high temperatures do to brakes.
A SW track update will do wonders. Trust me.
Zero to 60 is about 98 feet an 60- zero is almost the same. Brakes aren’t the problem, temperature is.
The stability control uses braking to keep the car straight. Its basically applying the brakes during acceleration.Can you elaborate "Brakes aren’t the problem, temperature is."
That is not true. They used somewhat for front traction control in turns. They are not used in the rear unless it's a serious traction loss, because there is no open differential in the rear.Yes it will make a huge difference.
It's also possible that you don't drive fast enough.It’s stock brakes are excellent. Definitely enough with track pads.
I have at least 20 track day sessions and tons of autocross.
the sway of the car and the number one critique I have is the seating.
No side bolster‘s are a killer. almost impossible to stay in your seat.
The iBooster doesn't use vacuum at all, so it isn't running out of that. It uses an electric motor to apply break pressure, so I don't think your problem is the iBooster.The electronic Bosch iBooster isn't very 'stout.' As in, it runs out of vacuum pretty quick, and takes too long to build back up. I've had encounters where I smash the brake pedal, let up, hit it again, and then get a message that braking force is reduced.
Looks like you have a performance 3.It's also possible that you don't drive fast enough.
I had the performance 3 before track mode, it was awful. I was actually going to sell the car until the trackmode was released.That is not true. They used somewhat for front traction control in turns. They are not used in the rear unless it's a serious traction loss, because there is no open differential in the rear.
run it in normal mode next time you’re at the track. Then get back to me.
