Certainly not for reasons of efficiency. Replacing an AC motor with a SRPM motor at the front of Raven INCREASED the vehicles range, while adding an AC Induction motor to the front of Model 3 AWD has DECREASED the range.
The
most likely reason Tesla chose an AC Induction motor for the front of Model 3 is that the SRPM motor is simply too powerful to be used in this lighter car:
- 3rd part dyno tests have MEASURED 380 hp at the wheel with LR RWD
- Semi uses 4 SRPMs to haul 80K lbs gross wt, or 20,000 lbs per motor
I'd like to see is a tear-down of the Model 3 AWD to compare size and weight of the front AC motor to SRPM. How about it
@Ingineer ? You up for some more spelunking?
Similarly, time's ripe to do a chassis dyno test on the AWD 3. I'd like to know 3 things:
- how much power does the font AC induction motor make
- what is the power increase in the front motor with the $2K "Performance Boost"
- how does it compare to Raven's front SRPM motor power + weight
Cheers!
