Has anyone ever seen battery_heater_on = true in the charge state response?
I am querying through many days worth of data including times I know I saw a battery heater notification on the dashboard and I see nothing.
Is there a verified way of knowing that the battery heater is actually on? I am trying to see if some of my vampire drain is from battery heating and/or 12V battery charging.
This was leaving my GF's house Sunday morning at 10:48am.
cat *.xml | | grep battery_heater_on | grep -v false | grep -v null
tesla_112xx_stats-20131215104807.xml: <battery_heater_on>true</battery_heater_on>
<vehicle112xx>
<charge_state>
<charging_state>Disconnected</charging_state>
<charge_limit_soc>90</charge_limit_soc>
<charge_limit_soc_std>90</charge_limit_soc_std>
<charge_limit_soc_min>50</charge_limit_soc_min>
<charge_limit_soc_max>100</charge_limit_soc_max>
<charge_to_max_range>false</charge_to_max_range>
<not_enough_power_to_heat>false</not_enough_power_to_heat>
<max_range_charge_counter>0</max_range_charge_counter>
<fast_charger_present>false</fast_charger_present>
<battery_range>43.73</battery_range>
<est_battery_range>17.79</est_battery_range>
<ideal_battery_range>49.62</ideal_battery_range>
<battery_level>29</battery_level>
<battery_current>-29.1</battery_current>
<charge_energy_added>38.5</charge_energy_added>
<charge_miles_added_rated>130.5</charge_miles_added_rated>
<charge_miles_added_ideal>148.0</charge_miles_added_ideal>
<charger_voltage>0</charger_voltage>
<charger_pilot_current>0</charger_pilot_current>
<charger_actual_current>0</charger_actual_current>
<charger_power>0</charger_power>
<time_to_full_charge>null</time_to_full_charge>
<charge_rate>0.0</charge_rate>
<charge_port_door_open>false</charge_port_door_open>
<scheduled_charging_start_time>null</scheduled_charging_start_time>
<scheduled_charging_pending>false</scheduled_charging_pending>
<user_charge_enable_request>null</user_charge_enable_request>
<charge_enable_request>false</charge_enable_request>
<eu_vehicle>false</eu_vehicle>
<charger_phases>null</charger_phases>
</charge_state>
<climate_state>
<inside_temp>9.0</inside_temp>
<outside_temp>-11.0</outside_temp>
<driver_temp_setting>19.8</driver_temp_setting>
<passenger_temp_setting>19.8</passenger_temp_setting>
<is_auto_conditioning_on>false</is_auto_conditioning_on>
<is_front_defroster_on>0</is_front_defroster_on>
<is_rear_defroster_on>false</is_rear_defroster_on>
<fan_status>10</fan_status>
</climate_state>
<drive_state>
<shift_state>D</shift_state>
<speed>9</speed>
<latitude>XX</latitude>
<longitude>-YY</longitude>
<heading>179</heading>
<gps_as_of>1387126082</gps_as_of>
</drive_state>
<gui_settings>
<gui_distance_units>mi/hr</gui_distance_units>
<gui_temperature_units>F</gui_temperature_units>
<gui_charge_rate_units>mi/hr</gui_charge_rate_units>
<gui_24_hour_time>false</gui_24_hour_time>
<gui_range_display>Rated</gui_range_display>
</gui_settings>
<vehicle_state>
<df>0</df>
<dr>0</dr>
<pf>0</pf>
<pr>0</pr>
<ft>0</ft>
<rt>0</rt>
<car_version>1.49.22</car_version>
<locked>true</locked>
<sun_roof_installed>true</sun_roof_installed>
<sun_roof_state>closed</sun_roof_state>
<sun_roof_percent_open>0</sun_roof_percent_open>
<dark_rims>false</dark_rims>
<wheel_type>Base19</wheel_type>
<has_spoiler>true</has_spoiler>
<roof_color>None</roof_color>
<perf_config>Sport</perf_config>
<exterior_color>Red</exterior_color>
</vehicle_state>
</vehicle112xx>
